DHCPv6 Message Format
The show ipv6 dhcp relay statistics command does not display the packet count in the statistics for DHCPv6 Advertise and Reconfigure messages, because it is sent from the DHCPv6 server to DHCPv6 client directly, not through the relay server.
Solicit (1)
A DHCPv6 client sends a Solicit message to locate DHCPv6 servers.
Advertise (2)
A server sends an Advertise message to indicate that it is available for DHCP service, in response to a Solicit message received from a client.
Request (3)
A client sends a Request message to request configuration parameters, including IP addresses or delegated prefixes, from a specific server.
Confirm (4)
A client sends a Confirm message to any available server to determine whether the addresses it was assigned are still appropriate to the link to which the client is connected. This could happen when the client detects either a link-layer connectivity change or if it is powered on and one or more leases are still valid. The confirm message confirms whether the client is still on the same link or whether if it has been moved. The actual leases are not validated, only the prefix portion of the addresses or delegated prefixes.
Renew (5)
A client sends a Confirm message to any available server to determine whether the addresses it was assigned are still appropriate to the link to which the client is connected. This could happen when the client detects either a link-layer connectivity change or if it is powered on and one or more leases are still valid. The confirm message confirms whether the client is still on the same link or whether it has been moved. The actual leases are not validated, only the prefix portion of the addresses or delegated prefixes.
Rebind (6)
A client sends a Rebind message to any available server to extend the lifetimes on the addresses assigned to the client and to update other configuration parameters. This message is sent after a client receives no response to a Renew message.
Reply (7)
A server sends a Reply message containing assigned addresses and configuration parameters in response to a Solicit, Request, Renew, or Rebind message received from a client. A server sends a Reply message containing configuration parameters in response to an Information-request message. A server sends a Reply message in response to a Confirm message confirming or denying that the addresses assigned to the client are appropriate to the link to which the client is connected. A server sends a Reply message to acknowledge receipt of a Release or Decline message.
Release (8)
A client sends a Release message to the server that assigned addresses to the client to indicate that the client is not using one or more of the assigned addresses.
Decline (9)
A client sends a Decline message to a server to indicate that the client has determined that one or more addresses assigned by the server are already in use on the link to which the client is connected.
Reconfigure (10)
A server sends a Reconfigure message to a client to inform the client that the server has new or updated configuration parameters. The client needs to initiate a Renew/Reply or Information-request/Reply transaction with the server in order to receive the updated information.
Information-request (11)
A client sends an Information-request message to a server to request configuration parameters without the assignment of any IP addresses to the client.
Relay-forward (12)
A relay agent sends a Relay-forward message to relay messages to servers, either directly or through another relay agent. The received message, either a client message or a Relay-forward message from another relay agent, is encapsulated in an option in the Relay-forward message.
Relay-reply (13)
A server sends a Relay-reply message to a relay agent containing a message that the relay agent delivers to a client. The Relay-reply message may be relayed by other relay agents for delivery to the destination.
Table 1. DHCPv4 message versus DHCPv6 messageThe table lists the DHCPv4 and DHCPv6 message types:
DHCPv6 message type DHCPv4 message type
Solicit (1) DHCPDISCOVER
Advertise (2) DHCPOFFER
Request (3), Renew (5), Rebind (6) DHCPREQUEST
Reply (7) DHCPPACK/DHCPNAK
Release (8) DHCPRELEASE
Information-Request (11) DHCPINFORM
Decline (9) DHCPDECLINE
Confirm (4) None
Reconfigure (10) DHCPFORCERENEW
Relay-Forward(12), Relay-Reply (13) None
