  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the router ospf command to enter OSPF router configuration mode and enable OSPFv2 globally.
    device(config)# router ospf
  3. Enter the no graceful restart command to disable GR on the device.
    device(config-router-ospf-vrf-default-vrf)# no graceful-restart
The following example disables GR.
