The supported scale for OSPFv3 across all VRF instances is as follows:
Table 1. Supported scale across all VRFs
Description Number supported
Maximum number of OSPFv3 VRF Instances 1024
Maximum number of OSPFv3 Areas 1024
Number of OSPFv3 Interfaces 2048
Number of OSPFv3 Neighbors 2048
Maximum Number of OSPFv3 Routes 64k (65536)
The supported scale for OSPFv3 per VRF instance is as follows:
Table 2. Supported scale per VRF
Number of OSPFv3 Interfaces 256
Number of OSPFv3 Neighbors 256
