Important
Important
This procedure requires a system reload to activate the profile configuration.
  1. From privileged EXEC mode, enter global configuration mode.
    device# configure terminal
  2. Enter hardware configuration mode.
    device(config)# hardware
  3. Enable a BGP flowspec profile in TCAM.
    device(config-hardware)# profile tcam border-routing
  4. (Optional) Enable forward or drop statistics using one of the following options.
    device(config-hardware)# profile counters counter-profile-1
    device(config-hardware)# profile counters counter-profile-4
  5. Access privileged EXEC mode.
    device(config-hardware)# exit
  6. Activate the profile configuration.
    device# reload system
The following example summarizes the commands in this procedure.
