After enabling IPv6 VRRPv3 you can configure tracking the port status of other interfaces on the device that are not configured for VRRP. Any link down or up events from tracked interfaces can result in dynamic changes in the virtual router priority and a potential master device switchover. The configured priority must be less than the VRRPv3 or VRRP-Ev3 priorities.
Enter the
configure command to access global configuration mode.
To globally enable VRRPv3, enter the
ipv6 protocol vrrp command.
device(config)# ipv6 protocol vrrp
Enter the
interface ve
command with an associated VLAN number.
device(config)# interface ve 2018
In this example, virtual Ethernet (ve) interface configuration mode is entered and the interface is assigned with a VLAN number of 2018.
Enter an IPv6 address for the interface using the
ipv6 address
command.
device(config-ve-2018)# ipv6 address 2001:2018:8192::125/64
Enter the
ipv6 vrrp-group
command with a number to assign a VRRPv3 group to the device.
device(config-ve-2018)# ipv6 vrrp-group 18
In this example, VRRP group configuration mode is entered.
Enter the
virtual-ip
command to assign a link-local virtual IPv6 address to a VRRPv3 group.
device(config-vrrp-group-18)# virtual-ip fe80::2018:1
In this example, the link-local IPv6 address of the virtual router is assigned to VRRPv3 group 18. The first virtual IP address entered enables the VRRPv3 session.
Enter the
track command with an interface and a priority to enable the tracking of ports that are not configured as VRRP interfaces.
device(config-vrrp-group-18)# track ethernet 1/5 priority 15
Enter the
no preempt-mode command to disable preemption.
device(config-vrrp-group-18)# no preempt-mode
Preemption can be disabled when you do not want to preempt an existing master with a higher priority device.
Enter the
priority command to configure the priority of the virtual router. In VRRPv3, the virtual router with the highest priority becomes the master VRRPv3 device.
device(config-vrrp-group-18)# priority 120
The following example shows how to configure an IPv6 VRRPv3 session and enable the tracking of a 10 GbE interface.
device# configure
device(config-ve-2018)# ipv6 address 2001:2018:8192::122/64
