  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the router isis command to enter IS-IS router configuration mode and enable IS-IS on the device.
    device(config)# router isis
  3. Enter the lsp-gen-interval command and specify a value to change the LSP generation interval.
    device(config-isis-router)# lsp-gen-interval 60
The following example changes the LSP generation interval to 60 seconds.
