Ensure that OSPFv3 areas are assigned.
All device interfaces must be assigned to one of the defined areas on an OSPFv3 device. When an interface is assigned to an area, all corresponding subnets on that interface are automatically included in the assignment.
  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the interface command and specify an interface.
    device(config)# interface ethernet 1/1
  3. Enter the ipv6 address command to add an IPv6 address to the interface.
    device(conf-if-eth-1/1)# ipv6 address 2001:1:0::1:1/64
  4. Enter the ipv6 ospf area command.
    device(conf-if-eth-1/1)# ipv6 ospf area 0
    Area 0 is assigned to the specified interface with the IPv6 address of 2001:1:0:1::1/64.
  5. Enter the exit command to return to global configuration mode.
    device(conf-if-eth-1/1)# exit
  6. Enter the interface command and specify an interface.
    device(config)# interface ethernet 2/1
  7. Enter the ipv6 address command to add an IPv6 address to the interface.
    device(conf-if-eth-2/1)# ipv6 address 2001:1:0::2:1/64
  8. Enter the ipv6 ospf area command.
    device(conf-if-eth-2/1)# ipv6 ospf area 1
    Area 1 is assigned to the specified interface with the IPv6 address of 2001:1:0:2::1/64.
The following example configures and enables OSPFv3 on two specified interfaces, and assigns an interface to two router areas.
