  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the router ospf command to enter OSPF router configuration mode and enable OSPFv2 on the device.
    device(config)# router ospf
  3. Enter the graceful-restart command using the helper-disable keyword to disable the GR helper.
    device(config-router-ospf-vrf-default-vrf)# graceful-restart helper-disable
The following example disables the GR helper.
