Enter the
configure terminal command to access global configuration mode.
device# configure terminal
Enter the
ipv6 router ospf command to enter OSPFv3 router configuration mode and enable OSPFv3 globally.
device(config)# ipv6 router ospf
Enter the
timers command with the
spf parameter.
device(config-ipv6-router-ospf-vrf-default-vrf)# timers spf 1 5
The SPF delay is changed to 1 second and the SPF hold time is changed to 5 seconds.
The following example changes the SPF delay and hold time.
