  1. Enter the configure terminal command to access global configuration mode.
    device# configure terminal
  2. Enter the router isis command to enter IS-IS router configuration mode and enable IS-IS on the device.
    device(config)# router isis
  3. Enter the log invalid-lsp-packets command to enable the logging of invalid LSP packets.
    device(config-isis-router)# log invalid-lsp-packets
The following example enables the logging of invalid LSP packets.
