This task is performed on any device that is designated as a backup VRRP device, and the functionality is activated if the backup device becomes a master VRRP device. Repeat this task for all devices that are to be designated as backup devices.
The accept mode functionality does not support SSH packets.
  1. On the device designated as a backup VRRP device, from privileged EXEC mode, enter global configuration mode.
    device# configure terminal
  2. Disable VRRP accept mode for all instances of VRRP on the device.
    device(config)# vrrp-acceptmode-disable
    You can re-enable accept mode by using the no form of this command.
