To view an AP 8132 model
access point‘s deployment area humidity:
Select the Statistics menu from the Web UI.
Expand the System
node from the navigation pane (on the left-hand side of the screen). The
System node expands to display the RF Domains created within the managed
network.
Expand an RF Domain node, and select one of
it's connected access points. The access point's statistics menu displays in the
right-hand side of the screen, with the Health tab selected by
default.
Expand the Environment menu.
Select the Humidity tab.
The Statistics > AP 8132 > Environment > Humidity tab displays.
Refer to the Humidity table to assess the
sensor's detected humidity fluctuations within the AP 8132‘s
immediate deployment area.
Humidity is measured in percentage.
The table displays the Current Humidity (percent) and the
20 Minute Average Humidity (percent). Compare these two
items to determine whether the AP 8132‘s deployment location remains consistently humid (often a by-product of
temperature).
Refer to the Humidity Trend Over Last Hour
graph to assess the fluctuation in humidity over the last hour. Use this
graph in combination with the Temperature and Motions graphs (in particular) to
assess the deployment area‘s activity levels.
Refer to the Humidity Trend Over Last Day
graph to assess whether deployment area humidity is consistent across
specific hours of the day. Use this information to help determine whether the AP 8132 can
be upgraded or powered off during specific hours of the day.
Select Refresh at any time to update the
screen‘s statistics counters to their latest values.
