For information on setting captive portal duration and authentication settings, refer to Captive Portal Policies.
To view the controller or service platform guest user utilization:
| Name | Lists the administrator assigned name of the client utilizing the controller or service platform for guest access to the wireless network. |
| Configured Time (days:hrs:mins:secs) | Displays the restricted permissions each listed client was initially configured for their captive portal guest user session with this managing controller or service platform. |
| Remaining Time (days:hrs:mins:secs) | Displays the time each listed client has remaining in their captive portal guest user session with this managing controller or service platform. |
| Configured Kilobytes | Lists the maximum configured bandwidth consumable by the listed guest user (in kilobytes). |
| Remaining Kilobytes | Lists the remaining bandwidth available to the listed guest user (in kilobytes). This is the difference between the configured (maximum) bandwidth and the user‘s current utilization. |
| Configured Downlink Rate (kbps) | Specifies the download speed configured for the listed guest user. When bandwidth is available, the user can download data at the specified rate (in kilobytes per second). If a guest user has a bandwidth based policy and exceeds the specified data limit, their speed is throttled to the defined reduced downlink rate. For more information, refer to Defining User Pools. |
| Configured Uplink Rate (kbps) | Specifies the upload speed dedicated to the listed guest user. When bandwidth is available, the user is able to upload data at the specified rate (in kilobytes per second). If a guest user has a bandwidth based policy and exceeds the specified data limit, their speed is throttled to the reduced uplink rate. For more information, refer toDefining User Pools . |
| Current Downlink Rate (Kbps) | Lists the listed guest user‘s current downlink rate in kbps. Use this information to assess whether this user‘s configured downlink rate is adequate for their session requirements and whether their reduced downlink rate need adjustment if the configured downlink rate is exceeded. For more information, refer to Defining User Pools. |
| Current Uplink Rate (Kbps) | Lists the listed guest user‘s current uplink rate in kbps. Use this information to assess whether this user‘s configured uplink rate is adequate for their session requirements and whether their reduced uplink rate need adjustment if the configured uplink rate is exceeded. For more information, refer to Defining User Pools . |
