efa tenant service bgp peer-group create --name <bgp-pg-name> --tenant <tenant-name> --pg-name <device-ip:pg-name> --pg-asn <device-ip,pg-name:remote-asn> --pg-bfd-enable <device-ip,pg-name:true|false> --pg-remove-private-as <device-ip,pg-name:true|false>
efa tenant service bgp peer-group update --name <bgp-pg-name> --tenant <tenant-name> --operation peer-group-add --pg-name <device-ip:pg-name> --pg-asn <device-ip,pg-name:remote-asn> --pg-bfd-enable <device-ip,pg-name:true|false> --pg-remove-private-as <device-ip,pg-name:true|false>
efa tenant service bgp peer-group create --name ten1bgppg1 --tenant ten1 --pg-name 10.20.246.15:pg1 --pg-asn 10.20.246.15,pg1:55001 --pg-bfd-enable 10.20.246.15,pg1:true --pg-remove-private-as 10.20.246.15,pg1:true --pg-name 10.20.246.16:pg1 --pg-asn 10.20.246.16,pg1:55001 --pg-bfd-enable 10.20.246.16,pg1:true --pg-remove-private-as 10.20.246.16,pg1:true efa tenant service bgp peer-group update --name ten1bgppg1 --tenant ten1 --operation peer-group-add --pg-name 10.20.246.15:pg2 --pg-asn 10.20.246.15,pg2:55002 --pg-bfd-enable 10.20.246.15,pg2:true --pg-remove-private-as 10.20.246.15,pg2:true --pg-name 10.20.246.16:pg2 --pg-asn 10.20.246.16,pg2:55002 --pg-bfd-enable 10.20.246.16,pg2:true --pg-remove-private-as 10.20.246.16,pg2:true efa tenant service bgp peer-group show --detail ======================================================================= Name : ten1bgppg1 Tenant : ten1 State : bgp-pg-state-created Peer Group ---------- Device IP : 10.20.246.15 Peer Group : pg1 Remote ASN : 55001 Next Hop Self : false BFD Enabled : true BFD Interval : BFD Rx : BFD Multiplier : Remove Private AS: true Dev State : provisioned App State : cfg-in-sync Device IP : 10.20.246.15 Peer Group : pg2 Remote ASN : 55002 Next Hop Self : false BFD Enabled : true BFD Interval : BFD Rx : BFD Multiplier : Remove Private AS: true Dev State : provisioned App State : cfg-in-sync Device IP : 10.20.246.16 Peer Group : pg1 Remote ASN : 55001 Next Hop Self : false BFD Enabled : true BFD Interval : BFD Rx : BFD Multiplier : Remove Private AS: true Dev State : provisioned App State : cfg-in-sync Device IP : 10.20.246.16 Peer Group : pg2 Remote ASN : 55002 Next Hop Self : false BFD Enabled : true BFD Interval : BFD Rx : BFD Multiplier : Remove Private AS: false Dev State : provisioned App State : cfg-in-sync =======================================================================
Rack1-Device1# show running-config router bgp router bgp local-as 4200000000 capability as4-enable fast-external-fallover neighbor pg1 peer-group neighbor pg1 remote-as 55001 neighbor pg1 remove-private-as neighbor pg1 bfd neighbor pg2 peer-group neighbor pg2 remote-as 55002 neighbor pg2 remove-private-as neighbor pg2 bfd neighbor 10.20.20.4 remote-as 4200000000 neighbor 10.20.20.4 next-hop-self address-family ipv4 unicast network 172.31.254.46/32 network 172.31.254.123/32 maximum-paths 8 graceful-restart ! address-family ipv4 unicast vrf ten1vrf1 redistribute connected maximum-paths 8 ! address-family ipv6 unicast ! address-family ipv6 unicast vrf ten1vrf1 redistribute connected maximum-paths 8 ! address-family l2vpn evpn graceful-restart ! ! |
Rack1-Device2# show running-config router bgp router bgp local-as 4200000000 capability as4-enable fast-external-fallover neighbor pg1 peer-group neighbor pg1 remote-as 55001 neighbor pg1 remove-private-as neighbor pg1 bfd neighbor pg2 peer-group neighbor pg2 remote-as 55002 neighbor pg2 password remove-private-as neighbor pg2 bfd neighbor 10.20.20.5 remote-as 4200000000 neighbor 10.20.20.5 next-hop-self address-family ipv4 unicast network 172.31.254.46/32 network 172.31.254.176/32 maximum-paths 8 graceful-restart ! address-family ipv4 unicast vrf ten1vrf1 redistribute connected maximum-paths 8 ! address-family ipv6 unicast ! address-family ipv6 unicast vrf ten1vrf1 redistribute connected maximum-paths 8 ! address-family l2vpn evpn graceful-restart ! ! |
For information about commands and supported parameters to configure remove-private-as attribute, see Extreme Fabric Automation Command Reference, 2.7.0 .
