Creation of EFA entities (PO and EPG) on an admin down device followed by the Deletion of the same EFA entities (PO and EPG) on the same admin down device used to fail even though the configuration was never pushed to the devices.
Succeed the deletion of the EFA entities (PO and EPG) if the resultant configuration to be deleted has never been pushed to the devices.
The pre-provisioned config is present in EFA DB and not present on the SLX.
efa inventory admin-state show --ip 10.20.246.15 +----------------------+--------------+ | NAME | VALUE | +----------------------+--------------+ | Device IP | 10.20.246.15 | +----------------------+--------------+ | Admin State | down | +----------------------+--------------+ | Health Check Status | Disable | +----------------------+--------------+ |
efa inventory admin-state show --ip 10.20.246.16 +----------------------+--------------+ | NAME | VALUE | +----------------------+--------------+ | Device IP | 10.20.246.16 | +----------------------+--------------+ | Admin State | up | +----------------------+--------------+ | Health Check Status | Disable | +----------------------+--------------+ |
efa tenant po create --name ten1po1 --tenant ten1 --port 10.20.246.15[0/1],10.20.246.16[0/1] --speed 10Gbps --negotiation active efa tenant vrf create --name ten1vrf1 --tenant ten1 efa tenant epg create --name ten1epg1 --tenant ten1 --po ten1po1 --switchport-mode trunk --ctag-range 11-12 --anycast-ip 11:10.0.11.1/24 --anycast-ip 12:10.0.12.1/24 --vrf ten1vrf1 efa tenant service bgp peer create --name ten1bgppeer1 --tenant ten1 --ipv4-uc-nbr 10.20.246.15,ten1vrf1:10.0.0.0,65001 --ipv4-uc-nbr 10.20.246.16,ten1vrf1:10.1.0.0,65001 efa tenant service bgp peer-group create --name ten1bgppeergroup1 --tenant ten1 --pg-name 10.20.246.15:pg1 --pg-asn 10.20.246.15,pg1:65010 --pg-name 10.20.246.16:pg1 --pg-asn 10.20.246.16,pg1:65010 efa tenant po show +---------+--------+----+--------------------------+--------+-------------+--------------+-------------------+-------------+------------+-----------------+-----------+ | Name | Tenant | ID | Description | Speed | Negotiation | MinLinkCount | Ports | LacpTimeout | State | Dev-State | App-State | +---------+--------+----+--------------------------+--------+-------------+--------------+-------------------+-------------+------------+-----------------+-----------+ | ten1po1 | ten1 | 1 | EFA Port-channel ten1po1 | 10Gbps | active | 1 | 10.20.246.15[0/1] | long | po-created | not-provisioned | cfg-ready | | | | | | | | | 10.20.246.16[0/1] | | | | | +---------+--------+----+--------------------------+--------+-------------+--------------+-------------------+-------------+------------+-----------------+-----------+ efa tenant service bgp peer-group show =============================================================================================================================================================== Name : ten1bgppeergroup1 Tenant : ten1 State : bgp-pg-state-created Description : +--------------+-----------------+------------+-------------+--------------+--------+----------------+---------------+------------------+-----------------+-------------+ | Device IP | PEER-GROUP-NAME | REMOTE ASN | BFD Enabled | BFD Interval | BFD Rx | BFD Multiplier | Next-Hop-Self | Update-Source-IP | Dev-state | App-state | +--------------+-----------------+------------+-------------+--------------+--------+----------------+---------------+------------------+-----------------+-------------+ | 10.20.246.16 | pg1 | 65010 | false | 0 | 0 | 0 | false | | provisioned | cfg-in-sync | +--------------+-----------------+------------+-------------+--------------+--------+----------------+---------------+------------------+-----------------+-------------+ | 10.20.246.15 | pg1 | 65010 | false | 0 | 0 | 0 | false | | not-provisioned | cfg-ready | +--------------+-----------------+------------+-------------+--------------+--------+----------------+---------------+------------------+-----------------+-------------+ =============================================================================================================================================================== efa tenant vrf show --name ten1vrf1 --tenant ten1 =============================================================================================================================================================== Name : ten1vrf1 Vrf State : vrf-device-created Vrf Device State : not-provisioned Vrf App State : cfg-ready Tenant Name : ten1 Routing Type : distributed L3 VNI : 8191 IRB BD : 4095 IRB VE : 8191 BR BD : BR VE : BR VNI : 4096 RH max path : RH ecmp enable : Graceful restart enable : Route Target : import 101:101 : export 101:101 Static Route : Switch-IP->Network,Nexthop-IP[Route-Distance], ... : Local Asn : Static Route BFD : Switch-IP->[DestIP,SourceIP][Interval,Min-Rx,Multiplier], ... : Max Path : 8 Redistribute : connected =============================================================================================================================================================== efa tenant epg show =============================================================================================================================================================== Name : ten1epg1 Tenant : ten1 Description : Type : extension Ports : POs : : unstable : ten1po1 Port Property : switchport mode : trunk : native-vlan-tagging : false NW Policy : ctag-range : 11-12 : vrf : ten1vrf1 [unstable] : l3-vni : 8191 Network Property [Flags : * - Native Vlan] +------+--------+--------------+--------------+---------+--------------------------------+-------------------------+-------------+-----------------------+---------------------+-----------------+-----------+ | Ctag | L2-Vni | Anycast-IPv4 | Anycast-IPv6 | BD-name | Local IP (Device-IP->Local-IP) | Ctag-Description | Mtu-IPv6-ND | ManagedConfig-IPv6-ND | OtherConfig-IPv6-ND | Dev-state | App-state | +------+--------+--------------+--------------+---------+--------------------------------+-------------------------+-------------+-----------------------+---------------------+-----------------+-----------+ | 11 | 11 | 10.0.11.1/24 | | | | Tenant L3 Extended VLAN | | False | False | not-provisioned | cfg-ready | +------+--------+--------------+--------------+---------+--------------------------------+-------------------------+-------------+-----------------------+---------------------+-----------------+-----------+ | 12 | 12 | 10.0.12.1/24 | | | | Tenant L3 Extended VLAN | | False | False | not-provisioned | cfg-ready | +------+--------+--------------+--------------+---------+--------------------------------+-------------------------+-------------+-----------------------+---------------------+-----------------+-----------+ For 'unstable' entities, run 'efa tenant po/vrf show' for details =============================================================================================================================================================== efa tenant service bgp peer show ============================================================================================================================================================================================ Name : ten1bgppeer1 Tenant : ten1 State : bs-state-created Description : Static Peer: +--------------+----------+------+---------+-----------+------------+-------------+--------------+--------+----------------+---------------+------------------+-----------------+-------------+ | Device IP | VRF | AFI | SAFI | REMOTE IP | REMOTE ASN | BFD Enabled | BFD Interval | BFD Rx | BFD Multiplier | Next Hop Self | Update Source IP | Dev-state | App-state | +--------------+----------+------+---------+-----------+------------+-------------+--------------+--------+----------------+---------------+------------------+-----------------+-------------+ | 10.20.246.16 | ten1vrf1 | ipv4 | unicast | 10.1.0.0 | 65001 | false | 0 | 0 | 0 | false | | provisioned | cfg-in-sync | +--------------+----------+------+---------+-----------+------------+-------------+--------------+--------+----------------+---------------+------------------+-----------------+-------------+ | 10.20.246.15 | ten1vrf1 | ipv4 | unicast | 10.0.0.0 | 65001 | false | 0 | 0 | 0 | false | | not-provisioned | cfg-ready | +--------------+----------+------+---------+-----------+------------+-------------+--------------+--------+----------------+---------------+------------------+-----------------+-------------+ Dynamic Peer: +-----------+-----+-----+------+--------------+------------+--------------+-----------+-----------+ | Device IP | VRF | AFI | SAFI | Listen Range | Peer Group | Listen Limit | Dev-state | App-state | +-----------+-----+-----+------+--------------+------------+--------------+-----------+-----------+ ============================================================================================================================================================================================
Scenario (Deletion of pre-provisioned config) | EFA 2.3.2 | EFA 2.4.0 |
efa tenant service bgp peer delete --name ten1bgppeer1 --tenant ten1 |
BgpService Deletion Failed: Device: 10.20.246.15 Bgp Peer Error: Device is administratively down |
BgpService deleted successfully |
efa tenant service bgp peer-group delete --name ten1bgppeergroup1 --tenant ten1 |
BgpService deletion Failed: Device: 10.20.246.15 Bgp Peer Error: Device is administratively down |
efa tenant epg delete --name ten1epg1 --tenant ten1 |
EndpointGroup deletion failed: Error: [10.20.246.15] device(s) are administratively down |
EndpointGroup: ten1epg1 deleted successfully |
efa tenant po delete --name ten1po1 --tenant ten1 |
Portchannel deletion failed: Error: [10.20.246.15] device(s) are administratively down |
PortChannel: ten1po1 deleted successfully |
