Existing behavior in EFA 2.3.0
        Configuration or Deconfiguration is never attempted on admin down switching devices.
        Target Devices
            Devices on which the configuration is intended to be pushed.
        Complete Failure Topology
                    - Topology having atleast one single-homed device in admin down state or
                        atleast one dual-homed device pair with both the devices in admin down state
                        is a “complete failure topology”.
                    - Any Tenant CLI or REST API of
                        create or delete nature attempted on the target devices having “complete
                        failure topology” is rejected with an appropriate error and result in a
                        complete failure. EFA does not have any configuration recipe prepared for
                        this REST API or CLI as the entire request is rejected. For example, an EPG
                        (endpoint group) create attempted on a single-homed device which is admin
                        down state.
        Complete Success Topology
                    - Topology with all the
                        single-homed devices and all the dual-homed device pair in admin up state is
                        a “complete success topology”.
                        success topology” results in the configuration recipe preparation for all
                        the target devices and the configuration is attempted on all the target
                        devices as all the target devices are in “admin up” state.
        Partial Success Topology
                - Topology which is not “complete failure topology” and having at least one
                    dual-homed device pair with one of the device in admin down state and the other
                    device in admin up state is a “partial success topology”.
                    create nature attempted on the target devices having “partial success topology”
                    will result in the configuration being attempted onto the “admin up” devices and
                    configuration not being attempted onto the “admin down” devices. Even though
                    configuration is not attempted for “admin down” devices, the configuration is
                    treated as success for the “admin down” devices.
Configuration recipe is
                        prepared and persisted in EFA for all the devices and the configuration is
                        auto reconciled with the devices when the “admin down” devices transition to
                        “admin up”.
When the devices are in the “admin up” state, the EFA
                        intended configuration synchronizes with the device configuration.
                    delete nature attempted on the target devices having “partial success topology”
                    results in deconfiguration attempted on the “admin up” devices, and
                    deconfiguration not attempted on the “admin down” devices. The CLI or REST API
                    operation fails with an appropriate error indicating that the deconfiguration
                    not being attempted on the “admin down” devices.
The reason being EFA does not
                        want to leave stale configurations on the devices because if the stale
                        configurations are left on the devices, then bringing the devices (having
                        stale configurations) back into EFA is erroneous considering the full
                        brownfield support is missing in EFA. You can retry the same CLI or REST API
                        operation after the “admin down” devices transition to “admin up” state so
                        that the deconfiguration is attempted on all the devices. You can always use
                        “force” option available in REST API to forcefully delete the entities from
                        EFA even in case of partial success topology.
                - Drift between the EFA intended
                    configuration and device config is shown in the efa tenant debug device
                        drift CLI or REST API output and in the corresponding entity GET
                    or SHOW output (for example, efa tenant epg show
                    and efa tenant po
                        show in the form of “app-state” and “dev-state”.
                - EFA blocks the tenant
                    reconciliation API and rest of the tenant APIs support partial success
                    behavior.
