Use of the EFA command line requires a
valid, logged-in user.
Verify the status of the EFA
deployment using one of the following methods.
- Run the SLX show efa status command.
- Run the EFA efactl
status script (or the efa status
command, as an alternative).
Log in to EFA.
$ efa login --username <username>
Password: <password>
The <username> variable is optional. If you do not provide a user name,
log-in defaults to the current (Unix) user.
With a successful log-in,
the command prompt shows the logged-in user in green text. If the log-in is not
successful, the command prompt is displayed in red text.
To log out of EFA, run the efa logout command.
