The following table describes information added to this guide for the Extreme Fabric Automation 2.7.0 software release.
| Feature | Description | Link |
| Traffic Mirroring support | Describes Traffic Mirroring and its configuration procedure. | Traffic Mirroring |
| Backup Routing support on BGP peer | Describes Backup Routing neighbors configuration on BGP peer | Configure Backup Routing Neighbors on BGP Peer |
| DRC Optimization | Describes Drift and Reconcile (DRC) Optimization, it's architecture, and details about parallel DRC operations. | Drift and Reconcile |
| Infrastructure improvements and upgrades | Describes Northbound IPv6 support in EFA | Northbound IPv6 support |
| Describes Active/Standby approach to HA. | Firmware Download Restart on HA Failover or Inventory Service Restart | |
| Updated the EFA system backup location to include the EFA version and build number in the backup tar file name. | CLI Commands for Backups | |
| Manage Gatway changes in EFA. | Change the Default Gateway of a TPVM | |
| Multiple Anycast IP support | Describes multiple anycast IP configuration | Configure Multiple Anycast IP |
| EFA login to the switch with different user names triggering as a security violation on the switch | Describes the solution to resolve the security violation issue on the switches. | EFA Certificate Management |
| RBAC: Observing "export EFA_TOKEN" command suggestion while a tenant user logging in | Describes the solution when an RBAC user gets the export EFA_TOKEN suggestion while logging in to EFA. | Known Limitations in EFA |
| EFA CLI or REST request with scale config taking longer than 15 minutes fails with error "service is not available or internal server error has occurred" | Describes the solution when you get an error while trying to delete tenants. | Known Limitations in EFA |
| Edit active fabric settings | Describes which fabric settings can be updated in small data center and Clos fabric. | Edit Fabric Settings |
| Manual DRC: Failed to reconcile ACL rule | Describes full-fledged data consistency support. | Access Control List and Data Consistency Support |
