You can back up and restore the EFA system, including the database and certificates.
$ efa system backup Generating backup of EFA... Backup Location: /apps/efa_logs/backup/EFA-2021-02-10T13-21-46.413.tar --- Time Elapsed: 10.401999384s ---
$ efa system restore EFA-2021.01.12-11.19.52.tar (Version:2.3.2-GA, Generated by: User) EFA-2021-01-12T04.59.09.tar (Version:2.4.0-7171, Generated by: User) EFA-2021-01-12T13.50.00.tar (Version:2.4.0-121, Generated by: User) EFA-2021-01-12T13.50.51.tar (Version:2.4.0-121, Generated by: System) EFA-2021-01-12T16.11.47.tar (Version:2.4.0-1211, Generated by: System) EFA-Upgrade-2.3.2-GA.tar (Version:2.3.2-GA, Generated by: System)
Choose backup option:1 Selected: EFA-2021.01.12-11.19.52.tar Performing EFA restore using EFA-2021.01.12-11.19.52.tar Generating backup before initiating restore BACKUP_TAR: /apps/efa_logs/backup/EFA-2021.01.12-11.19.52.tar Stopping all EFA services All pods are terminated Migrating database Completed database migration Checking if all PODS are in ready state... Restore operation is successful --- Time Elapsed: 9m3.079104969s ---
efa certificates device install --ips <ip-adddr> certType [ http|token]
