Add and Delete Management Subinterfaces
Use the EFA CLI to add and delete management subinterfaces.
  1. Run the following command to add a management subinterface:
    efa mgmt subinterface create --name <name> --ip-address <ip-subnet>
    --vlan-id <VLAN>
    • If a management network with the same name exists, the operation fails.
    • The changes made by this operation span three different components:
      • Subinterface creation under the physical NIC
      • Keepalived configuration changes (for high-availability deployments)
      • Ingress controller changes
    • If any operation to the component fails, it is marked as a failed operation and the configurations return to the previous state.
  2. Run the following commands to delete a management subinterface:
    efa mgmt subinterface delete --name <name>
    If a management network with the name exists, it is deleted. Otherwise, the correct response is provided in the command output.
$ efa mgmt subinterface?
Management subinterface commands
Usage:
  efa mgmt subinterface [command]
Available Commands:
  create        Create sub-interface (sub-interface)
  delete        Delete sub-interface (sub-interface)
  show          List of sub-interfaces (sub-interfaces)
Flags:
  -h, --help          help for sub-interface
Use "efa mgmt subinterface [command] --help" for more information about a command.
$ efa mgmt subinterface create -h
Create management subinterface (sub-interface)
Usage:
  efa mgmt subinterface create [flags]
Flags:
      --name string         Name of the sub-interface
      --vlan-id int         VLAN Id of sub-interface
      --ip-address string   IP Address of sub-interface including subnet mask.
                            Example: 10.24.80.150/24
  -h, --help                help for create
$ efa subinterface delete -h
Delete management subinterface (sub-interface)
Usage:
  efa mgmt subinterface delete [flags]
Flags:
  -h, --help          help for delete
$ efa mgmt subinterface show -h
List of management sub-interfaces (sub-interfaces)
Usage:
  efa mgmt subinterface show [flags]
 Flags:
   -h, --help          help for show
$ efa mgmt subinterface create --name server1 --vlan-id 20 --ip-address
          20.20.20.2/24
Subinterface server1 created successfully
$ efa mgmt subinterface delete --name server1
Subinterface server1 deleted successfully
| Sub-Interface | Parent Interface | Vlan |   IP Subnet   |
| server1       | eth0             | 20   | 20.20.20.2/24 |
| server2       | eth0             | 50   | 50.50.50.2/24 |
Management Subinterfaces Details
$ efa mgmt subinterface show --name server1
Management Subinterface Details
