EPG: Network Property Description
The EPG (endpoint group) Network Property Description enables you to configure “description” per EFA tenant ctag which gets configured on the SLX as VLAN or BD description.
The default value of “description” is provided in the following table:
Network Type Description
L2 Extension Tenant L2 Extended VLAN or BD
L3 Extension Tenant L3 Extended VLAN or BD
L3 Handoff Tenant L3 Hand-off VLAN or BD
L3 Extension EVPN IRB Tenant L3 Extended IRB BD
You can provide the EPG network “description” during EPG create and EPG update (ctag-range-add) operations.
2.3.2 to 2.4.0 Upgrade Handling
During the upgrade from EFA 2.3.2 to EFA 2.4.x, and 2.5.0 for all the EPG networks, the default “description” is determined and the app-state is set to “cfg-refreshed” so that the user triggers DRC (in EFA 2.4.0) to push the derived network “description” on to the SLX.
EPG Create
efa tenant epg create --name <epg-name> --tenant string <tenant-name> --port <list-of-phy> --po <list-of-po>
               --switchport-mode <access |trunk | trunk-no-default-native>
               --ctag-range string <ctag-range> --ctag-description <ctag:description>
EPG Update
efa tenant epg update --name <epg-name> --tenant <tenant-name> --operation <ctag-range-add>
                --ctag-range <ctag-range> --ctag-description <ctag:description>
efa tenant show
|   Name   |  Type   | VLAN Range | L2VNI Range | L3VNI Range | VRF Count | Enable BD |         Ports         |
|  bdTen1  | private |   21-30    |             |             |    10     |   true    | 10.20.246.15[0/11-20] |
|          |         |            |             |             |           |           | 10.20.246.16[0/11-20] |
| vlanTen1 | private |   11-20    |             |             |    10     |   false   | 10.20.246.16[0/1-10]  |
|          |         |            |             |             |           |           | 10.20.246.15[0/1-10]  |
efa tenant vrf create –name ten1vrf1 –tenant vlanTen1
efa tenant vrf create –name ten2vrf2 –tenant bdTen1
VLAN Based L2 Extension EPG
efa tenant epg create --name ten1epg1 --tenant vlanTen1 --port 10.20.246.15[0/1],10.20.246.16[0/1]
--switchport-mode trunk --ctag-range 11-12 --ctag-description 12:Ten1VLANNW1
VLAN Based L3 Extension EPG
efa tenant epg create --name ten1epg2 --tenant vlanTen1 --port 10.20.246.15[0/1],10.20.246.16[0/1]
--switchport-mode trunk --ctag-range 13-14 --ctag-description 14:Ten1VLANNW2 --anycast-ip
13:10.0.13.1/24 --anycast-ip 14:10.0.14.1/24 --vrf ten1vrf1
VLAN Based L3 Handoff EPG
efa tenant epg create --name ten1epg3 --tenant vlanTen1 --type l3-hand-off
--port 10.20.246.15[0/1],10.20.246.16[0/1] --switchport-mode trunk --ctag-range 15-16 --ctag-description 16:Ten1VLANNW3
BD Based L2 Extension EPG
efa tenant epg create --name ten2epg1 --tenant bdTen1 --port 10.20.246.15[0/11],10.20.246.16[0/11]
--switchport-mode trunk --ctag-range 21-22 --ctag-description 22:Ten2BDNW1
BD Based L3 Extension EPG
efa tenant epg create --name ten2epg2 --tenant bdTen1 --port 10.20.246.15[0/11],10.20.246.16[0/11]
--switchport-mode trunk --ctag-range 23-24 --ctag-description 24:Ten2BDNW2 --anycast-ip
23:10.0.23.1/24 --anycast-ip 24:10.0.24.1/24 --vrf ten2vrf
efa tenant epg show --detail
Switch Config
Rack1-Device1# show running-
config bridge-domain
bridge-omain 1 p2mp
 description Tenant L2 Extended BD
 pw-profile default
 logical-interface ethernet 0/11.21
 bpdu-drop-enable
 local-switching
bridge-domain 2 p2mp
 description Ten2BDNW1
 pw-profile default
 logical-interface ethernet 0/11.22
 bpdu-drop-enable
 local-switching
bridge-domain 3 p2mp
 description Tenant L3 Extended BD
 pw-profile Tenant-profile
 router-interface Ve 4099
 logical-interface ethernet 0/11.23
 bpdu-drop-enable
 local-switching
 suppress-arp
bridge-domain 4 p2mp
 description Ten2BDNW2
 router-interface Ve 4100
 logical-interface ethernet 0/11.24
 bpdu-drop-enable
 local-switching
 suppress-arp
bridge-domain 4093 p2mp
 description Tenant L3 Extended IRB BD
 router-interface Ve 8189
 bpdu-drop-enable
 local-switching
bridge-domain 4094 p2mp
 router-interface Ve 8190
 bpdu-drop-enable
 local-switching
Rack1-Device2# show running-
bridge-domain 1 p2mp
 pw-profile default
 bpdu-drop-enable
 local-switching
 pw-profile default
 bpdu-drop-enable
 local-switching
 bpdu-drop-enable
 local-switching
 suppress-arp
 bpdu-drop-enable
 local-switching
 suppress-arp
 bpdu-drop-enable
 local-switching
 bpdu-drop-enable
 local-switching
Rack1-Device1#show running-config vlan
vlan 11
 description Tenant L2 Extended VLAN
vlan 12
 description Ten1VLANNW1
vlan 13
 router-interface Ve 13
 suppress-arp
 description Tenant L3 Extended VLAN
vlan 14
 router-interface Ve 14
 suppress-arp
 description Ten1VLANNW2
vlan 15
 description Tenant L3 Hand-off VLAN
vlan 16
 description Ten1VLANNW3
Rack1-Device1#
Rack1-Device2# show running-config vlan
vlan 11
vlan 12
vlan 13
 suppress-arp
vlan 14
 suppress-arp
vlan 15
vlan 16
Rack1-Device2#
