Configure default-originate to advertise default route on BGP Peer
  1. Run the following command to create a BGP Peer on a tenant VRF:
    efa tenant service bgp peer create --name <bgp-peer-name> --tenant <tenant-name>
               		--ipv4-uc-nbr <device-ip,vrf-name:neighbor-ip,remote-asn>
               		--ipv4-uc-nbr-bfd <device-ip,vrf-name:neighbor-ip,true|false>
              		 --ipv4-uc-nbr-default-originate <device-ip,vrf-name:neighbor-ip,true/false>
               		--ipv4-uc-nbr-default-originate-route-map <device-ip,vrf-name:neighbor-ip,route-map>
  2. Run the following command to update a BGP Peer on a tenant VRF:
    efa tenant service bgp peer update --name <bgp-peer-name> --tenant <tenant-name>
               		--operation peer-add
    The ipv4-uc-nbr-default-originate-route-map attribute is an optional attribute.
    Example:
    efa tenant service bgp peer create --name ten1bgppeer1 --tenant tenant11
    		--ipv4-uc-nbr 10.20.246.3,v1:10.20.30.40,50000
    		--ipv4-uc-nbr-bfd 10.20.246.3,v1:10.20.30.40,true
    		--ipv4-uc-nbr-default-originate 10.20.246.3,v1:10.20.30.40,true
    		--ipv4-uc-nbr 10.20.246.4,v1:10.20.30.40,50000
    		--ipv4-uc-nbr-bfd 10.20.246.4,v1:10.20.30.40,true
    		--ipv4-uc-nbr-default-originate 10.20.246.4,v1:10.20.30.40,true
    		--ipv4-uc-nbr-default-originate-route-map 10.20.246.4,v1:10.20.30.40,rmap1
    §efa tenant service bgp peer-group show --detail
    Tenant         : tenant11
    State            : bgp-peer-created
    Description      :
    Static Peer
    Device IP                   : 10.20.246.4
    VRF                         : v1
    AFI                         : ipv4
    SAFI                        : unicast
    Remote IP                   : 10.20.30.40
    Remote ASN                  : 50000
    Next Hop Self               : false
    Update Source IP            :
    BFD Enabled                 : true
    BFD Interval                : 0
    BFD Rx                      : 0
    BFD Multiplier              : 0
    MD5 Password                :
    Remove Private AS           : false
    Default Originate           : true
    Default Originate Route Map : rmap1
    Prefix List In              :
    Prefix List Out             :
    Route Map In                :
    Route Map Out               :
    Dev State                   : provisioned
    App State                   : cfg-in-sync
    VRF                         : v1
    AFI                         : ipv4
    SAFI                        : unicast
    Remote IP                   : 10.20.30.50
    Remote ASN                  : 50000
    Update Source IP            :
    BFD Enabled                 : true
    BFD Interval                : 0
    BFD Rx                      : 0
    BFD Multiplier              : 0
    MD5 Password                :
    Default Originate           : false
    Prefix List In              :
    Prefix List Out             :
    Route Map In                :
    Route Map Out               :
    Device IP                   : 10.20.246.3
    VRF                         : v1
    AFI                         : ipv4
    SAFI                        : unicast
    Remote ASN                  : 50000
    Update Source IP            :
    BFD Enabled                 : true
    BFD Interval                : 0
    BFD Rx                      : 0
    BFD Multiplier     : 0
    MD5 Password                :
    Prefix List In              :
    Prefix List Out             :
    Route Map In                :
    Route Map Out               :
    VRF                         : v1
    AFI                         : ipv4
    SAFI                        : unicast
    Remote ASN                  : 50000
    Update Source IP            :
    BFD Enabled                 : true
    BFD Interval                : 0
    BFD Rx                      : 0
    BFD Multiplier              : 0
    MD5 Password                :
    Default Originate Route Map : tt
    Prefix List In              :
    Prefix List Out             :
    Route Map In                :
    Route Map Out               :
    efa tenant service bgp peer show --detail
    Tenant           : tenant11
    Description      :
    Static Peer
    	VRF                         : v1
    	AFI                         : ipv4
    	SAFI                        : unicast
    	Remote ASN                  : 50000
    	Update Source IP            :
    	BFD Enabled                 : true
    	BFD Interval                : 0
    	BFD Rx                      : 0
    	BFD Multiplier              : 0
    	MD5 Password                :
    	Prefix List In              :
    	Prefix List Out             :
    	Route Map In                :
    	Route Map Out               :
    	VRF                         : v1
    	AFI                         : ipv4
    	SAFI                        : unicast
    	Remote ASN                  : 50000
    	Update Source IP            :
    	BFD Enabled                 : true
    	BFD Interval                : 0
    	BFD Rx                      : 0
    	BFD Multiplier              : 0
    	MD5 Password                :
    	Prefix List In              :
    	Prefix List Out             :
    	Route Map In                :
    	Route Map Out               :
  3. Verify the switch configuration on the SLX device.
    10.20.246.3
    SLX# show running-config router bgp
    address-family ipv4 unicast vrf v1
      redistribute connected
      neighbor 10.20.30.40 remote-as 50000
      neighbor 10.20.30.40 default-originate
      neighbor 10.20.30.40 bfd
      neighbor 10.40.40.252 remote-as 4200000000
      neighbor 10.40.40.252 next-hop-self
      maximum-paths 8
    10.20.246.4
      neighbor 10.20.30.40 default-originate route-map rmap1
      neighbor 10.40.40.253 remote-as 4200000000
      neighbor 10.40.40.253 next-hop-self
      maximum-paths 8
    For information about commands and supported parameters to configure default-originate attribute, see Extreme Fabric Automation Command Reference, 2.7.0 .
