Configure Multiple Anycast IP
You can provide multiple anycast IP address per tenant ctag when you create or update an EPG, add ctag-range, add VRF, and add or delete anycast IP. The multiple anycast IP address is configured under the interface Ve of the switching hardware.
  1. To configure multiple anycast IP when you create an EPG, run the following command:
    efa tenant epg create --name <epg-name> --tenant <tenant-name>
               --switchport-mode <mode>
    	    --port <port-list> --po <po-list>
              --ctag-range <ctag-range>
              --vrf <vrf-name>
    	   --anycast-ip <value> --anycast-ip <value>
    	   --anycast-ipv6 <value> --anycast-ipv6 <value>
  2. To configure multiple anycast IP when you update an EPG, run the following command:
    efa tenant epg update --name <epg-name> --tenant <tenant-name>
    	          --operation vrf-add | ctag-range-add |anycast-ip-add | anycast-ip-delete|
    	          --ctag-range <ctag-range> --vrf  <vrf-name>
Example:
Multiple anycast IP configuration example when you create an EPG:
efa tenant epg create --name e1 --tenant tenant11 --po po1 --switchport-mode trunk-no-default-native --vrf v1 --ctag-range 101-102  --anycast-ip 101:1.1.1.254/24 --anycast-ip 101:2.1.1.254/24 --anycast-ip 101:3.1.1.254/24 --anycast-ipv6 101:1::1/124 --anycast-ipv6 102:2::1/124
efa tenant epg show –detail
Tenant        : tenant11
Type          : extension
State         : epgf-with-port-group-and-ctag-range
Description   :
Ports         :
POs           : po1
Port Property : SwitchPort Mode               : trunk-no-default-native
              : Single-Homed BFD Session Type : Auto
NW Policy     : Ctag Range                    : 101-103
              : VRF                           : v1
              : L3Vni                         : 8192
| MAC ACL IN | MAC ACL OUP | IP ACL IN | IP ACL OUT | IPv6 ACL IN |
POrt Property ACLs
| Port |  Dev State   |  App State  |
| po1  | provisionied | cfg-in-sync |
Port Property States
| Ctag |    Ctag       | L2Vni | BD Name | Anycast IPv4 | Anycast IPv6 | Suppress |         Local IP         | IP MTU | IPv6 ND |    IPv6 ND     |     IPv6 ND  |  Dev State  |  App State  |
|      |  Description  |       |         |              |              |  ARP/ND  |   [Device-IP->Local-IP]  |        |   MTU   | Managed Oonfig | Other Config |             |             |
| 101  |   Tenant L3   |10000  |         | 2.1.1.254/24 |   1::1/124   |    T/T   | 10.20.246.3->1.10.1.1/24 |        |         |      false     |     false    | porvisioned | cfg-in-sync |
|      | Extended VLAN |       |         | 3.1.1.254/24 |              |          |                          |        |         |                |              |             |             |
|      |               |       |         | 1.1.1.254/24 |              |          |                          |        |         |                |              |             |             |
| 102  |   Tenant L3   |10001  |         |              |   2::1/124   |    T/T   |                          |        |         |      false     |     false    | porvisioned | cfg-in-sync |
|      | Extended VLAN |       |         |              |              |          |                          |        |         |                |              |             |             |
Network Property [Flags : * - Native Vlan]
| Ctag | IPv6 ND Prefix | No Advertise | Valid Lifetime | Preferred Lifetime | Config Type |
IPv6 ND Prefix Flags
| Ctag | MAC ACL Prefix | MAC ACL OUT | IP ACL IN | IP ACL OUT | IPv6 ACL IN |
Network Property ACLs
For 'unstable' entities, run 'efa tenant po/vrf show' for details
10.20.246.25
SLX# show running-config interface Ve
interface Ve 101
 vrf forwarding v1
 ip anycast-address 1.1.1.254/24
 ip anycast-address 2.1.1.254/24
 ip anycast-address 3.1.1.254/24
 ipv6 anycast-address 1::1/124
 no shutdown
interface Ve 102
 vrf forwarding v1
 ipv6 anycast-address 2::1/124
 no shutdown
interface Ve 4090
 ip address 10.20.20.2/31
 no shutdown
interface Ve 5120
 vrf forwarding v1
 ipv6 address use-link-local-only
 no shutdown
10.20.246.26
interface Ve 101
 vrf forwarding v1
 no shutdown
interface Ve 102
 vrf forwarding v1
 no shutdown
interface Ve 4090
 ip address 10.20.20.3/31
 no shutdown
interface Ve 5120
 vrf forwarding v1
 no shutdown
Multiple anycast IP configuration example when you update an EPG:
efa  tenant epg update --name e1 --tenant tenant11 --operation anycast-ip-add --anycast-ip 101:4.1.1.1/24
10.20.246.25
interface Ve 101
 vrf forwarding v1
 ip anycast-address 4.1.1.1/24
 no shutdown
interface Ve 102
 vrf forwarding v1
 no shutdown
interface Ve 4090
 no shutdown
interface Ve 5120
 vrf forwarding v1
 no shutdown
10.20.246.26
interface Ve 101
 vrf forwarding v1
 no shutdown
interface Ve 102
 vrf forwarding v1
 no shutdown
interface Ve 4090
 no shutdown
interface Ve 5120
 vrf forwarding v1
 no shutdown
