Device Certificates
        The HTTPS server certificate from EFA is presented to a client when that client connects
            to its northbound interface.
        During the registration of an SLX device in EFA, the following configuration changes are
            made on the device.
                - The public certificate for
                    verifying an EFA token is copied to the device as an OAuth2 certificate.
                - A syslog certificate is installed
                    on the device.
                - EFA generates the HTTPS
                    certificate for the SLX device. The certificate is copied to the device, HTTP
                    mode is disabled on the device, and HTTPS is enabled on the device.
                - OAuth2 is enabled as the primary
                    mode of authentication. Fallback is set to "local login."
                - Managed devices contain the
                    expiration date of an inventory certificate. If a device certificate is within
                    30 days of expiration, it pushes an event to the notification using the get certs
                    command.
        You can use the efa inventory
                device list command to verify the status of the certificates on the
            device. If the Cert/Key Saved
            column contains "N," then certificates are not installed.
        You can use the efa certificates
                device install --ips <ip-adddr> certType [ http|token] command to
            install the HTTPS or OAuth2 certificate on one or more devices.
