Use the native commands to configure the NTP server on the SLX device. The configuration is persisted in the EFA database. DRC is supported.
efa inventory device ntp server create ? Flags: --ip string Comma separated range of device IP addresses. --ntp-ip string NTP server IP address --auth-key int Authentication key ID. Values 1 to 65535 --auth-key-name string Key name --encryption-type string Encryption type. Valid values are md5, sha1 --trusted-key bool Trusted key. --fabric string fabric name. -h, --help help for ntp
Example:
efa inventory device ntp server create –ntp-ip 3.3.3.3 –-auth-key 1 –-auth-key-name ntpsecret –-encryption-type md5 –trusted-key –-ip 10.20.246.10 efa inventory device ntp server create –ntp-ip 3.3.3.3 –-auth-key 1 –-auth-key-name ntpsecret –-encryption-type md5 –trusted-key –-fabic clos_fabric
SLX# show running-config ntp ntp authentication-key 1 md5 $9$750C7e0ayuI31YUga1Clmg== encryption-level 7 ntp authenticate ntp server 3.3.3.3 key 1
efa inventory device ntp server delete ? Flags: --ip string Comma separated range of device IP addresses. --ntp-ip string NTP server IP address --fabric string fabric name. -h, --help help for ntp
Example:
efa inventory device ntp server delete –-ntp-ip 3.3.3.3 –-ip 10.20.246.10 efa inventory device ntp server delete –-ntp-ip 3.3.3.3 –-fabric clos_fabric
efa inventory device ntp server list ? Flags: --ip string Comma separated range of device IP addresses. --fabric string fabric name. -h, --help help for ntp
Example:
efa inventory device ntp server ntp server list –-ip 10.20.246.10 efa inventory device ntp server ntp server list –-fabric clos_fabric
efa inventory device ntp disable-server ? Flags: --ip string Comma separated range of device IP addresses. --enable Disable ntp server. Valid values are yes/no. --list List disable-server on devices. --fabric string fabric name. -h, --help help for ntp
efa inventory device ntp disable-server –-enable yes –-ip 10.20.246.10
efa inventory device ntp disable-server –-enable no –-ip 10.20.246.10
efa inventory device ntp disable-server –-enable yes –-fabric clos_fabric
efa inventory device ntp disable-server –-enable no –-fabric clos_fabric
efa inventory device ntp disable-server --list --ip 10.20.246.10
efa inventory device ntp disable-server --list --fabric clos_fabric
