The table below captures the various attributes of the SNMP configuration interface for which DRC and idempotency is supported. A drift is identified if any of the fields below is modified through the SLX CLI or other management tool. A reconcile operation pushes the intended configuration to SLX, so keeping the SLX configuration in sync with EFA.
Regarding idempotency for creating an entry which already exists in EFA, an error message is returned stating that the user already exists.
Field | Identify Drift | Reconcile config | Idempotency | Comments |
Community deleted | Yes | Yes | No | A valid error message is shown when a non-existent community is deleted. |
Group name associated with community is modified | Yes | Yes | Not Applicable | |
Group deleted | Yes | Yes | Not Applicable | |
Modify group version. | No | No | Not Applicable | SLX does not support editing the SNMP group version. |
Modify read, review, or write view or notify view associated with group. | No | No | Not Applicable | SLX does not support editing the SNMP views associated with the group. |
Modify groupname associated with SNMP user. | Yes | Yes | Not Applicable | |
Modify authentication protocol associated with SNMP user. | Yes | Yes | Not Applicable | |
Modify authentication password associated with SNMP user. | Yes | Yes | Not Applicable | |
Modify privacy protocol associated with SNMP user. | Yes | Yes | Not Applicable | |
Modify privacy password associated with SNMP user. | Yes | Yes | Not Applicable | |
Delete SNMP user. | Yes | Yes | Not Applicable | A valid error message is shown when a non existent user is deleted. |
Modify encrypted keyword associated with SNMP user. | Yes | Yes | Not Applicable | |
Modify authentication type associated with group, meaning: auth, noauth, notify. | Yes | Yes | Not Applicable | |
Delete SNMP host entry. | Yes | Yes | No | A valid error message is shown when a non existent host is deleted. |
Update SNMP host security level. | No | No | Not Applicable | |
Update SNMP host source interface. | No | No | Not Applicable | |
Update SNMP host UDP port. | No | No | Not Applicable | |
Update SNMP host VRF. | No | No | Not Applicable | |
Update SNMP host engine id. | Yes | Yes | Not Applicable | |
Update of SNMP host notification type [traps, informs] | Yes | Yes | Not Applicable | |
Update of SNMP view MIB OID access [included, excluded] | Yes | Yes | Not Applicable |
