Provide an option to enable or disable suppress-arp or nd (supress address resolution protocol or neighbor discovery) at the tenant network level so that you can choose to enable suppress-arp or nd per tenant network.
This option is mainly useful for a single rack small data center deployment where the suppress-arp or nd configuration on tenant network is not needed.
efa tenant epg create --name <epg-name> --tenant <tenant-name> --port <port-list> --switchport-mode <trunk|access> --ctag-range <ctag-range> --anycast-ip <ctag:anycast-ipv4> --anycast-ipv6 <ctag:anycast-ipv6> --vrf ten1vrf1 --suppress-arp <ctag:true|false> --suppress-nd <ctag:true|false> efa tenant epg update --name <epg-name> --tenant <tenant-name> --operation vrf-add --anycast-ip <ctag:anycast-ipv4> --anycast-ipv6 <ctag:anycast-ipv6> --vrf ten1vrf1 --suppress-arp <ctag:true|false> --suppress-nd <ctag:true|false> efa tenant epg update --name <epg-name> --tenant <tenant-name> --operation ctag-range-add --ctag-range <ctag-range> --anycast-ip <ctag:anycast-ipv4> --anycast-ipv6 <ctag:anycast-ipv6> --suppress-arp <ctag:true|false> --suppress-nd <ctag:true|false> efa tenant epg update --name <epg-name> --tenant <tenant-name> --operation anycast-ip-add --anycast-ip <ctag:anycast-ipv4> --anycast-ipv6 <ctag:anycast-ipv6> --suppress-arp <ctag:true|false> --suppress-nd <ctag:true|false>
efa fabric show Fabric Name: default, Fabric Description: Default Fabric, Fabric Stage: 3, Fabric Type: clos, Fabric Status: created +------------+-----+-----------+-----+------+--------------+-----------+-------------------+-----------------+---------+-------+ | IP ADDRESS | POD | HOST NAME | ASN | ROLE | DEVICE STATE | APP STATE | CONFIG GEN REASON | PENDING CONFIGS | VTLB ID | LB ID | +------------+-----+-----------+-----+------+--------------+-----------+-------------------+-----------------+---------+-------+ +------------+-----+-----------+-----+------+--------------+-----------+-------------------+-----------------+---------+-------+ Fabric Name: fs, Fabric Description: , Fabric Stage: 3, Fabric Type: clos, Fabric Status: settings-updated Updated Fabric Settings: BGP-LL +-------------+-----+-----------+-------+-------+---------------------+-------------+-------------------+----------------------------------------------+---------+-------+ | IP ADDRESS | POD | HOST NAME | ASN | ROLE | DEVICE STATE | APP STATE | CONFIG GEN REASON | PENDING CONFIGS | VTLB ID | LB ID | +-------------+-----+-----------+-------+-------+---------------------+-------------+-------------------+----------------------------------------------+---------+-------+ | 10.20.246.1 | | SLX-1 | 64512 | Spine | provisioned | cfg in-sync | NA | NA | NA | 1 | | 10.20.246.7 | | SLX | 65000 | Leaf | provisioning failed | cfg ready | IA,IU,MD,DA | SYSP-C,MCT-C,MCT-PA,BGP-C,INTIP-C,EVPN-C,O-C | 2 | 1 | | 10.20.246.8 | | slx-8 | 65000 | Leaf | provisioned | cfg in-sync | NA | NA | 2 | 1 | +-------------+-----+-----------+-------+-------+---------------------+-------------+-------------------+----------------------------------------------+---------+-------+ FABRIC SETTING: BGPLL - BGP Dynamic Peer Listen Limit, BGP-MD5 - BGP MD5 Password , BFD-RX - Bfd Rx Timer, BFD-TX - Bfd Tx Timer, BFD-MULTIPLIER - Bfd multiplier, BFD-ENABLE - Enable Bfd, BGP-MULTIHOP - BGP ebgp multihop, P2PLR - Point-to-Point Link Range, MCTLR - MCT Link Range, LOIP - Loopback IP Range CONFIG GEN REASON: LA/LD - Link Add/Delete, IA/ID/IU - Interface Add/Delete/Update, PLC/PLD/PLU - IPPrefixList Create/Delete/Update MD/MU - MCT Delete/Update, OD/OU - Overlay Gateway Delete/Update, EU/ED - Evpn Delete/Update, PC/PD/PU - RouterPim Create/Delete/Update DD - Dependent Device Update, DA/DR - Device Add/ReAdd, ASN - Asn Update, SYS - System Properties Update MD5 - BGP MD5 Password, BGPU - Router BGP Update, BGPLL - BGP Listen Limit, POU - Port Channel Update, NA - Not Applicable PENDING CONFIGS: MCT - MCT Cluster, O - Overlay Gateway, SYSP - System Properties, INTIP - Interface IP, BGP - Router BGP C/D/U - Create/Delete/Update, PA/PD - Port Add/Port Delete efa tenant show +------+---------+------------+-------------+-------------+-----------+-----------+-----------------------+ | Name | Type | VLAN Range | L2VNI Range | L3VNI Range | VRF Count | Enable BD | Ports | +------+---------+------------+-------------+-------------+-----------+-----------+-----------------------+ | ten1 | private | 11-20 | | | 10 | false | 10.20.246.15[0/1-10] | | | | | | | | | 10.20.246.16[0/1-10] | +------+---------+------------+-------------+-------------+-----------+-----------+-----------------------+ | ten2 | private | 21-30 | | | 10 | true | 10.20.246.15[0/11-20] | | | | | | | | | 10.20.246.16[0/11-20] | +------+---------+------------+-------------+-------------+-----------+-----------+-----------------------+ efa tenant vrf show +----------+--------+--------------+---------------------+--------------+----------+-----------+-----------+--------------------+-------------+-------------+ | Name | Tenant | Routing Type | Centralized Routers | Redistribute | Max Path | Local Asn | Enable GR | State | Dev State | App State | +----------+--------+--------------+---------------------+--------------+----------+-----------+-----------+--------------------+-------------+-------------+ | ten1vrf1 | ten1 | distributed | | connected | 8 | | false | vrf-device-created | provisioned | cfg-in-sync | +----------+--------+--------------+---------------------+--------------+----------+-----------+-----------+--------------------+-------------+-------------+ | ten2vrf1 | ten2 | distributed | | connected | 8 | | false | vrf-device-created | provisioned | cfg-in-sync | +----------+--------+--------------+---------------------+--------------+----------+-----------+-----------+--------------------+-------------+-------------+ efa tenant epg create --name ten1epg1 --tenant ten1 --port 10.20.246.15[0/1],10.20.246.16[0/1] --switchport-mode trunk --ctag-range 11-12 --anycast-ip 11:10.0.11.1/24 --anycast-ip 12:10.0.12.1/24 --anycast-ipv6 11:11::1/127 --anycast-ipv6 12:12::1/127 --vrf ten1vrf1 --suppress-arp 11:false –suppress-nd 12:false efa tenant epg create --name ten2epg1 --tenant ten2 --port 10.20.246.15[0/11],10.20.246.16[0/11] --switchport-mode trunk --ctag-range 21-22 --anycast-ip 21:10.0.21.1/24 --anycast-ipv6 21:21::1/127 --anycast-ip 22:10.0.22.1/24 --anycast-ipv6 22:22::1/127 --vrf ten2vrf1 --suppress-arp 21:false –suppress-nd 22:false efa tenant epg show –detail =============================================================================================================================================================== Name : ten1epg1 Tenant : ten1 Type : extension State : Description : Ports : 10.20.246.15[0/1] : 10.20.246.16[0/1] POs : Port Property : SwitchPort Mode : trunk : Native Vlan Tagging : false NW Policy : Ctag Range : 11-12 : VRF : ten1vrf1 : L3Vni : 8192 +------+-------------------------+-------+---------+--------------+--------------+--------+----------------------+---------+----------------+--------------+-------------+------------------+ | Ctag | Ctag | L2Vni | BD Name | Anycast IPv4 | Anycast IPv6 |Suppress| Local IP | IPv6 ND | IPv6 ND | IPv6 ND | Dev State | App State | | | Description | | | | | ARP/ND |[Device-IP->Local-IP] | Mtu | Managed Config | Other Config | | | +------+-------------------------+-------+---------+--------------+--------------+-------------+----------------------+---------+----------------+--------------+-------------+-------------+ | 11 | Tenant L3 Extended VLAN | 11 | | 10.0.11.1/24 | 11::1/127 | F/T | | | false | false | provisioned | cfg-in-sync | +------+-------------------------+-------+---------+--------------+--------------+-------------+----------------------+---------+----------------+--------------+-------------+-------------+ | 12 | Tenant L3 Extended VLAN | 12 | | 10.0.12.1/24 | 12::1/127 | T/F | | | false | false | provisioned | cfg-in-sync | +------+-------------------------+-------+---------+--------------+--------------+-------------+----------------------+---------+----------------+--------------+-------------+-------------+ =============================================================================================================================================================== =============================================================================================================================================================== Name : ten2epg1 Tenant : ten2 Type : extension State : Description : Ports : 10.20.246.15[0/11] : 10.20.246.16[0/11] POs : Port Property : SwitchPort Mode : trunk : Native Vlan Tagging : false NW Policy : Ctag Range : 21-22 : VRF : ten2vrf1 : L3Vni : 8191 +------+-----------------------+-------+--------------+--------------+--------------+--------+----------------------+---------+----------------+--------------+-------------+----------------+ | Ctag | Ctag | L2Vni | BD Name | Anycast IPv4 | Anycast IPv6 |Suppress| Local IP | IPv6 ND | IPv6 ND | IPv6 ND | Dev State | App State| | | Description | | | | | ARP/ND |[Device-IP->Local-IP] | Mtu | Managed Config | Other Config | | | +------+-----------------------+-------+--------------+--------------+--------------+-------------+----------------------+---------+----------------+--------------+-------------+-----------+ | 21 | Tenant L3 Extended BD | 4097 | Auto-BD-4097 | 10.0.21.1/24 | 21::1/127 | F/T | | | false | false | provisioned |cfg-in-sync| +------+-----------------------+-------+--------------+--------------+--------------+-------------+----------------------+---------+----------------+--------------+-------------+-----------+ | 22 | Tenant L3 Extended BD | 4098 | Auto-BD-4098 | 10.0.22.1/24 | 22::1/127 | T/F | | | false | false | provisioned |cfg-in-sync| +------+-----------------------+-------+--------------+--------------+--------------+-------------+----------------------+---------+----------------+--------------+-------------+-----------+ ===============================================================================================================================================================
