Change the Host Name or IP Address
You can change the host name, the IP address, and the virtual IP address after EFA is deployed.
Review the following host name requirements:
  • Host names must be unique and consist of numeric characters and lowercase alphabetic characters. Do not use uppercase alphabetic characters.
  • Hyphens are the only special characters allowed. No other special characters are allowed by Kubernetes for cluster formation or by the K3s service.
Host name changes are supported in single-node and multi-node deployments.
IP address changes are supported in single-node deployments.
Virtual IP address (VIP) changes are supported in multi-node deployments.
  1. To change the host name, take the following steps.
    1. In a multi-node deployment, stop the monitoring service.
      sudo systemctl stop efamonitor
    2. Change the host name of the system, such as with the following Linux command.
      hostnamectl set-hostname <new name>
    3. Add the new host name to /etc/hosts.
    4. Run the following command as a root user or as a user with sudo privileges.
      Important
      Important
      Do not reboot the system before running this command.
      sudo bash efa-change-hostname <old host name>
      Reading host name of the system
      Restarting mariadb service
      Restarting k3s service
      Checking k3s for the new host name
      Host is in ready state in k3s
      Setting current host as active node
      Deleting old host name references
      Waiting for EFA containers to start
      Successfully updated host name in EFA
      In a single-node deployment, EFA is not operational during this step. In a multi-node deployment, EFA remains operational if the command is running on the standby node. EFA is not operational if the command is running on the active node.
      In a TPVM deployment, you can run the command from /apps/bin/.
    5. In a multi-node deployment, start the monitoring service.
      sudo systemctl start efamonitor
  2. To change the IP address of a single-node deployment, take the following steps.
    1. Run the following command as a root user or as a user with sudo privileges.
      sudo bash efa-change-ip
      Updating IP in EFA
      Updating all files with new IP
      Deleting EFA services: gonotification-service gofabric-service gotenant-service
      goauth-service gorbac-service goinventory-service goopenstack-service
      govcenter-service gohyperv-service goraslog-service efa-api-docs gosystem-service
      Successfully updated IP in EFA
    2. After the IP address is updated, run source /etc/profile or open a new EFA session to log in.
  3. To change the VIP of a multi-node deployment, take the following steps.
    1. Stop the monitoring service.
    2. Run the following command as a root user or as a user with sudo privileges.
      sudo bash efa-change-vip <new vip>
      Updating all files with new VIP.
      Restarting services on nodes
      Updating services with new VIP
      Successfully updated VIP for the installation.
      EFA is not operational while this script runs.
    3. Start the monitoring service.
    4. Run source /etc/profile or open a new EFA session to log in.
    After the Virtual IP address (VIP) update is successful, it takes a few minutes to update new VIP in all the registered devices in EFA.
