You can use various commands and scripts to verify the status of the EFA system, to help troubleshoot, and to view details of EFA nodes, PODs, and services.
device# show efa status
               EFA version details
Version : 2.7.0
Build: 30
Time Stamp: 22-04-23:12:37:36
Mode: Secure
Deployment Type: multi-node
Deployment Platform: TPVM
Virtual IP: 10.20.59.183
Node IPs: 10.20.59.181,10.20.59.182
--- Time Elapsed: 12.253203ms ---
               EFA Status
| Node Name | Role    | Status | IP           |
| node-1    | active  | up     | 10.20.59.182 |
| node-2    | standby | up     | 10.20.59.181 |
--- Time Elapsed: 6.888985085s ---
                        On a multi-node installation:
+-----------+---------+--------+---------------+ | Node Name | Role | Status | IP | +-----------+---------+--------+---------------+ | tpvm2 | active | up | 10.20.216.242 | +-----------+---------+--------+---------------+ | tpvm1 | standby | up | 10.20.216.241 | +-----------+---------+--------+---------------+ --- Time Elapsed: 4.277420974s ---
On a single-node installation:
+-----------+--------+--------+-------------+ | Node Name | Role | Status | IP | +-----------+--------+--------+-------------+ | efa | active | up | 10.21.90.43 | +-----------+--------+--------+-------------+ --- Time Elapsed: 1.461512261s ---
extreme@node-1:~$ k3s kubectl -n efa get pods NAME READY STATUS RESTARTS AGE efa-api-docs-m6dgg 1/1 Running 0 19h gosnmp-service-vmmf7 1/1 Running 0 19h goopenstack-service-lf45g 1/1 Running 0 19h rabbitmq-ckvrq 1/1 Running 0 19h gorbac-service-2v8qh 1/1 Running 0 19h gonotification-service-9tjbg 1/1 Running 0 19h goauth-service-8zltv 1/1 Running 0 19h goinventory-service-gsxzb 1/1 Running 0 19h gohyperv-service-ng95v 1/1 Running 0 19h govcenter-service-rt9cc 1/1 Running 0 19h gofabric-service-nnv4m 1/1 Running 0 19h gosystem-service-wxnww 1/1 Running 0 19h gopolicy-service-hrl7d 1/1 Running 0 19h goraslog-service-fqdjm 1/1 Running 0 19h gotenant-service-v5nq2 1/1 Running 0 19h
$ systemctl status hostauth.service
hostauth.service - OS Auth Service
Loaded: loaded (/lib/systemd/system/hostauth.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2020-04-23 07:56:20 UTC; 23 h ago
Main PID: 23839 (hostauth)
Tasks: 5
CGroup: /system.slice/hostauth.service
        23839 /apps/bin/hostauth
Apr 23 07:56:20 tpvm2 systemd[1]: Started OS Auth Service
