| Mirror Type | Mirror Destination Type | Mirror Source | Mirror Destination |
| Port-Based | Span | Ethernet | Ethernet |
| Port-Based | Span | Port-Channel | Ethernet |
| Flow-Based | Span | Ethernet | Ethernet |
| Flow-Based | Span | Port-Channel | Ethernet |
| Flow-Based | Span |
                             Local VLAN (with device-ip)  |
                        Ethernet |
| Flow-Based | Span |
                             Global VLAN (without device-ip)  |
                        Ethernet |
| Flow-Based | Span |
                             Local VLAN Range (Supported Range format a-b)  |
                        Ethernet |
| Flow-Based | Span |
                             Global VLAN Range (Supported Range format a-b)  |
                        Ethernet |
| np-mac-acl-in | np-mac-acl-out | np-ip-acl-in | np-ip-acl-out | np-ipv6-acl-in | |
| L2 VLAN EPG | Supported | Supported | Not Supported | Not Supported | Not Supported |
| L3 VLAN EPG | Not Supported | Not Supported | Supported | Supported | Supported |
| L2 BD EPG | Not Supported | Not Supported | Not Supported | Not Supported | Not Supported |
| L3 BD EPG | Not Supported | Not Supported | Supported | Supported | Supported |
| pp-mac-acl-in | pp-mac-acl-out | pp-ip-acl-in | pp-ip-acl-out | pp-ipv6-acl-in | |
| Ethernet | Supported | Supported | Supported | Supported | Supported |
| Port-Channel | Supported | Not supported, except 9740 | Supported | Supported | Not supported, except 9740 |
