efa tenant epg create --name <epg-name> --tenant <tenant-name>
                 --switchport --switchport-mode trunk –ctag-range <ctag-range>
                 --port <mirror-source-port-list> --po <mirror-source-po-list>
                 --pp-mac-acl-in <acl-name> --pp-mac-acl-out <acl-name>
                 --pp-acl-in <acl-name> --pp-ip-acl-out <acl-name>
                 --np-mac-acl-in <ctag:acl-name> --np-mac-acl-out <ctag:acl-name>
                 --np-ip-acl-in <ctag:acl-name> --np-ip-acl-out <ctag:acl-name>
                efa tenant service mirror session create –name? <session-name> --tenant <tenant-name>
                    --source {<device-ip>,<eth | po | vlan>,<if-name>}
                    --type {<source-device-ip>,<eth | po | vlan>,<source-if-name>:<port-based | flow-based>}
	             --destination {<source-device-ip>,<eth | po | vlan>,<source-if-name> :
		        	<destination-device-ip>,<eth | po | vlan>,<destination-if-name}
                    --destination-type {<source-device-ip>,< eth | po | vlan>,<source-if-name>:<span>}
                    --direction {<source-device-ip>,< eth | po | vlan>,<source-if-name> : <tx | rx | both>}
(efa:root)root@node-2:~# efa tenant show
|     Name     |  Type   | VLAN Range | L2VNI Range | L3VNI Range | VRF Count | Enable BD |         Ports         |  Mirroring Ports    |
| sharedTenant | shared  |            |             |             |     0     |   false   |                       | 10.20.246.15[0/31]  |
|              |         |            |             |             |           |           |                       | 10.20.246.16[0/31]  |
|              |         |            |             |             |           |           |                       | 10.20.246.21[0/31]  |
|              |         |            |             |             |           |           |                       | 10.20.246.22[0/31]  |
|              |         |            |             |             |           |           |                       | 10.20.246.25[0/31]  |
|              |         |            |             |             |           |           |                       | 10.20.246.26[0/31]  |
|     ten1     | private |   11-20    |             |             |    10     |   false   | 10.20.246.15[0/1-10]  |                     |
|              |         |            |             |             |           |           | 10.20.246.16[0/1-10]  |                     |
|     ten2     | private |   21-30    |             |             |    10     |   false   | 10.20.246.15[0/11-20] |                     |
|              |         |            |             |             |           |           | 10.20.246.16[0/11-20] |                     |
(efa:root)root@node 2:~# efa tenant po show
|   Name  | Tenant | ID |  Speed  | MTU | Negotiation | Min Link |  Lacp   |        Ports      |    State   |  Dev State  |  App State  |
|         |        |    |         |     |             |   Count  | Timeout |                   |            |             |             |
| ten1po1 | ten1   |  2 |  10Gbps |     |    active   |    1     |   long  | 10.20.246.15[0/1] | po-created | provisioned | cfg-in-sync |
|         |        |    |         |     |             |          |         | 10.20.246.16[0/1] |            |             |             |
| ten2po1 | ten2   |  3 |  10Gbps |     |    active   |    1     |   long  | 10.20.246.15[0/11]| po-created | provisioned | cfg-in-sync |
|         |        |    |         |     |             |          |         | 10.20.246.16[0/11]|            |             |             |
                    | efa tenant epg create –name ten1epg1 –tenant ten1
            --switchport-mode trunk --po ten1po1 --ctag-range 11
            --pp-ip-acl-in ext-ip-permit-any-mirror-acl
            --pp-ip-acl-out  ext-ip-permit-any-mirror-acl
efa tenant service mirror session create –name ten1mirrorsession1 --tenant ten1
            --source 10.20.246.15,po,ten1po1
            --type 10.20.246.15,po,ten1po1:flow-based
            --destination 10.20.246.15,po,ten1po1:10.20.246.15,eth,0/31
            --destination-type 10.20.246.15,po,ten1po1:span
            --direction 10.20.246.15,po,ten1po1:both
efa tenant service mirror session create –name ten2mirrorsession1 --tenant ten2
            --source 10.20.246.15,po,ten2po1
            --type 10.20.246.15,po,ten2po1:flow-based
            --destination 10.20.246.15,po,ten2po1:10.20.246.15,eth,0/31
            --destination-type 10.20.246.15,po,ten2po1:span
            --direction 10.20.246.15,po,ten2po1:both | efa tenant epg create –name ten2epg1 –tenant ten2
            --switchport-mode trunk --po ten2po1 --ctag-range 21
efa tenant service mirror session create –name ten1mirrorsession2 --tenant ten1
            --source 10.20.246.16,po,ten1po1
            --type 10.20.246.16,po,ten1po1:flow-based
            --destination 10.20.246.16,po,ten1po1:10.20.246.16,eth,0/31
            --destination-type 10.20.246.16,po,ten1po1:span
            --direction 10.20.246.16,po,ten1po1:both
efa tenant service mirror session create –name ten2mirrorsession2 --tenant ten2
            --source 10.20.246.16,po,ten2po1
            --type 10.20.246.16,po,ten2po1:flow-based
            --destination 10.20.246.16,po,ten2po1:10.20.246.16,eth,0/31
            --destination-type 10.20.246.16,po,ten2po1:span
            --direction 10.20.246.16,po,ten2po1:both
| 10.20.246.15 SLX# show running-config ip access-list ip access-list extended ext-ip-permit-any-mirror-acl seq 10 permit ip any any mirror ! SLX# show running-config interface Port-channel 2,3 interface Port-channel 2 description EFA Port-channel ten1po1 cluster-client auto switchport switchport mode trunk switchport trunk allowed vlan add 11 no switchport trunk tag native-vlan ip access-group ext-ip-permit-any-mirror-acl in ip access-group ext-ip-permit-any-mirror-acl out no shutdown ! interface Port-channel 3 description EFA Port-channel ten2po1 cluster-client auto switchport switchport mode trunk switchport trunk allowed vlan add 21 no switchport trunk tag native-vlan ip access-group ext-ip-permit-any-mirror-acl in ip access-group ext-ip-permit-any-mirror-acl out no shutdown ! SLX# | 10.20.246.16 SLX# show running-config ip access-list ip access-list extended ext-ip-permit-any-mirror-acl seq 10 permit ip any any mirror ! SLX# show running-config interface Port-channel 2,3 interface Port-channel 2 description EFA Port-channel ten1po1 cluster-client auto switchport switchport mode trunk switchport trunk allowed vlan add 11 no switchport trunk tag native-vlan ip access-group ext-ip-permit-any-mirror-acl in ip access-group ext-ip-permit-any-mirror-acl out no shutdown ! interface Port-channel 3 description EFA Port-channel ten2po1 cluster-client auto switchport switchport mode trunk switchport trunk allowed vlan add 21 no switchport trunk tag native-vlan ip access-group ext-ip-permit-any-mirror-acl in ip access-group ext-ip-permit-any-mirror-acl out no shutdown ! SLX# |
| 10.20.246.15 SLX# show running-config monitor session monitor session 1 source port-channel 2 destination ethernet 0/31 direction both !monitor session 2 source port-channel 3 destination ethernet 0/31 direction both ! SLX# show monitor session 1 Session : 1 Type : SPAN Description : [None] State : Enabled Source Interface : Po 2 (Down) Destination Interface : Eth 0/31 (Down) Direction : Both Type : flow-based SLX# show monitor session 2 Session : 2 Type : SPAN Description : [None] State : Enabled Source Interface : Po 3 (Down) Destination Interface : Eth 0/31 (Down) Direction : Both Type : flow-based | 10.20.246.16 SLX# show running-config monitor session monitor session 1 source port-channel 2 destination ethernet 0/31 direction both !monitor session 2 source port-channel 3 destination ethernet 0/31 direction both ! SLX# show monitor session 1 Session : 1 Type : SPAN Description : [None] State : Enabled Source Interface : Po 2 (Down) Destination Interface : Eth 0/31 (Down) Direction : Both Type : flow-based SLX# show monitor session 2 Session : 2 Type : SPAN Description : [None] State : Enabled Source Interface : Po 3 (Down) Destination Interface : Eth 0/31 (Down) Direction : Both Type : flow-based |
