efa tenant epg create --name <epg-name> --tenant <tenant-name>
            --switchport --switchport-mode trunk –ctag-range <ctag-range>
            --port <mirror-source-port-list> --po <mirror-source-po-list>
            --pp-mac-acl-in <acl-name> --pp-mac-acl-out <acl-name>
            --pp-ip-acl-in <acl-name> --pp-ip-acl-out <acl-name>
            --np-mac-acl-in <ctag:acl-name> --np-mac-acl-out <ctag:acl-name>
            --np-ip-acl-in <ctag:acl-name> --np-ip-acl-out <ctag:acl-name>
                efa tenant service mirror session create –name <session-name> --tenant <tenant-name>
            --source {<device-ip>,<eth | po | vlan>,<if-name>}
            --type {<source-device-ip>,<eth | po | vlan>,<source-if-name>:<port-based | flow-based>}
            --destination {<source-device-ip>,<eth | po | vlan>,<source-if-name> :
                        <destination-device-ip>,<eth | po | vlan>,<destination-if-name}
            --destination-type {<source-device-ip>,< eth | po | vlan>,<source-if-name>:<span>}
            --direction {<source-device-ip>,< eth | po | vlan>,<source-if-name> : <tx | rx | both>}
(efa:root)root@node-2:~# efa tenant show
| Name   |  Type   | VLAN  | L2VNI | L3VNI | VRF   | Enable |         Ports        |   Mirroring Ports  |
|        |         | Range | Range | Range | Count | BD     |                      |                    |
| shared | Shared  |       |       |       |   0   | false  |                      | 10.20.246.16[0/31] |
| Tenant |         |       |       |       |       |        |                      | 10.20.246.21[0/31] |
|        |         |       |       |       |       |        |                      | 10.20.246.22[0/31] |
|        |         |       |       |       |       |        |                      | 10.20.246.25[0/31] |
|        |         |       |       |       |       |        |                      | 10.20.246.26[0/31] |
|  ten1  | private | 11-20 |       |       |   10  | false  | 10.20.246.15[0/1-10] |                    |
|        |         |       |       |       |       |        | 10.20.246.16[0/1-10] |                    |
|        |         |       |       |       |       |        | 10.20.246.21[0/1-10] |                    |
|        |         |       |       |       |       |        | 10.20.246.22[0/1-10] |                    |
|  ten2  | private | 21-30 |       |       |   10  | false  | 10.20.246.15[0/11-20]|                    |
|        |         |       |       |       |       |        | 10.20.246.16[0/11-20]|                    |
|        |         |       |       |       |       |        | 10.20.246.21[0/11-20]|                    |
|        |         |       |       |       |       |        | 10.20.246.22[0/11-20]|                    |
(efa:root)root@node 2:~# efa tenant po show
|   Name  | Tenant | ID |  Speed  | MTU | Negotiation | Min Link |  Lacp   |        Ports      |    State   |  Dev State  |  App State  |
|         |        |    |         |     |             |   Count  | Timeout |                   |            |             |             |
| ten1po1 | ten1   |  2 |  10Gbps |     |    active   |    1     |   long  | 10.20.246.15[0/1] | po-created | provisioned | cfg-in-sync |
|         |        |    |         |     |             |          |         | 10.20.246.16[0/1] |            |             |             |
| ten2po1 | ten2   |  3 |  10Gbps |     |    active   |    1     |   long  | 10.20.246.15[0/11]| po-created | provisioned | cfg-in-sync |
|         |        |    |         |     |             |          |         | 10.20.246.16[0/11]|            |             |             |
| ten1po2 | ten1   |  2 |  10Gbps |     |    active   |    1     |   long  | 10.20.246.21[0/1] | po-created | provisioned | cfg-in-sync |
|         |        |    |         |     |             |          |         | 10.20.246.22[0/1] |            |             |             |
| ten2po2 | ten2   |  3 |  10Gbps |     |    active   |    1     |   long  | 10.20.246.21[0/11]| po-created | provisioned | cfg-in-sync |
|         |        |    |         |     |             |          |         | 10.20.246.22[0/11]|            |             |             |
                                            efa tenant epg create –name ten1epg1 –tenant ten1
            --switchport-mode trunk --po ten1po1,ten1po2  --ctag-range 11
            --np-mac-acl-in 11:ext-mac-permit-any-mirror-acl
            --np-mac-acl-out 11:ext-mac-permit-any-mirror-acl
efa tenant service mirror session create –name ten1mirrorsession1 --tenant ten1
            --source vlan,11
            --type vlan,11:flow-based
            --destination-type vlan,11:span
            --destination vlan,11:10.20.246.15,eth,0/31
            --direction vlan,11:both
                                            efa tenant epg create –name ten2epg1 –tenant ten2
            --switchport-mode trunk --po ten2po1,ten2po2 --ctag-range 21
            --np-mac-acl-in 21:ext-mac-permit-any-mirror-acl
            --np-mac-acl-out 21:ext-mac-permit-any-mirror-acl
efa tenant service mirror session create –name ten2mirrorsession1 --tenant ten2
            --source vlan,21
            --type vlan,21:flow-based
            --destination-type vlan,21:span
            --destination vlan,21:10.20.246.16,eth,0/31
            --direction vlan,21:both
10.20.246.15SLX# show running-config mac access-list mac access-list extended ext-mac-permit-any-mirror-acl seq 10 permit any any mirror ! SLX# SLX# show running-config vlan 11,21 vlan 11 description Tenant L2 Extended VLAN mac access-group ext-mac-permit-any-mirror-acl in mac access-group ext-mac-permit-any-mirror-acl out ! vlan 21 description Tenant L2 Extended VLAN mac access-group ext-mac-permit-any-mirror-acl in mac access-group ext-mac-permit-any-mirror-acl out ! SLX#  |
                                    10.20.246.16SLX# show running-config mac access-list mac access-list extended ext-mac-permit-any-mirror-acl seq 10 permit any any mirror ! SLX# SLX# show running-config vlan 11,21 vlan 11 description Tenant L2 Extended VLAN mac access-group ext-mac-permit-any-mirror-acl in mac access-group ext-mac-permit-any-mirror-acl out ! vlan 21 description Tenant L2 Extended VLAN mac access-group ext-mac-permit-any-mirror-acl in mac access-group ext-mac-permit-any-mirror-acl out ! SLX#  |
                                    10.20.246.21SLX# show running-config mac access-list mac access-list extended ext-mac-permit-any-mirror-acl seq 10 permit any any mirror ! SLX# SLX# show running-config vlan 11,21 vlan 11 description Tenant L2 Extended VLAN mac access-group ext-mac-permit-any-mirror-acl in mac access-group ext-mac-permit-any-mirror-acl out ! vlan 21 description Tenant L2 Extended VLAN mac access-group ext-mac-permit-any-mirror-acl in mac access-group ext-mac-permit-any-mirror-acl out ! SLX#  |
                                    10.20.246.22SLX# show running-config mac access-list mac access-list extended ext-mac-permit-any-mirror-acl seq 10 permit any any mirror ! SLX# SLX# show running-config vlan 11,21 vlan 11 description Tenant L2 Extended VLAN mac access-group ext-mac-permit-any-mirror-acl in mac access-group ext-mac-permit-any-mirror-acl out ! vlan 21 description Tenant L2 Extended VLAN mac access-group ext-mac-permit-any-mirror-acl in mac access-group ext-mac-permit-any-mirror-acl out ! SLX#  |
10.20.246.15-16SLX# show running-config monitor session monitor session 1 source vlan 11 destination ethernet 0/31 direction both flow-based ! monitor session 2 source vlan 21 destination ethernet 0/31 direction both flow-based !SLX# SLX# show monitor session 1 Session : 1 Type : SPAN Description : [None] State : Enabled Source Interface : Vlan 11 Destination Interface : Eth 0/31 (Down) Direction : Both Type : flow-based SLX# show monitor session 2 Session : 2 Type : SPAN Description : [None] State : Enabled Source Interface : Vlan 21 Destination Interface : Eth 0/31 (Down) Direction : Both Type : flow-based SLX#  |
                                    10.20.246.21-22SLX# show running-config monitor session monitor session 1 source vlan 11 destination ethernet 0/31 direction both flow-based ! monitor session 2 source vlan 21 destination ethernet 0/31 direction both flow-based !SLX #SLX# show monitor session 1 Session : 1 Type : SPAN Description : [None] State : Enabled Source Interface : Vlan 11 Destination Interface : Eth 0/31 (Down) Direction : Both Type : flow-based SLX# show monitor session 2 Session : 2 Type : SPAN Description : [None] State : Enabled Source Interface : Vlan 21 Destination Interface : Eth 0/31 (Down) Direction : Both Type : flow-based SLX#  |
