Return Material Authorization
With the Return Material Authorization (RMA) process, you can replace a faulty device
with a new device that has the same configuration.
The high-level process is as follows. For specific steps and commands, see Replace a Faulty Device.
- Verify prerequisites.
- Periodic configuration backup
must be enabled on all devices that may need RMA. This prerequisite ensures
that you have the latest configuration file to be used for recovery.
- Maintenance mode must be
enabled upon reboot on all devices.
- Remove the faulty device and replace it with
the new device. Ports on this device must be administratively up and online.
The
ports on the new device must have the same connections as the old device. For
example, if the old device Ethernet port1 and port2 went to port3 and port4 of
another device, the new replacement device must have these exact same Ethernet
port connections.
- Configure the new device with the same
management IP address and credentials as the old device.
- Start the RMA process from the command line or
with the REST API.
As a best
practice, run the
efa
inventory rma execute command with the configuration backup ID so
that the configuration is properly restored. If you run the command without the
backup ID, you must manually update the configuration on the new
device.
During the RMA process, the following actions occur:
- The device boots up in
maintenance mode.
- EFA updates the device ID
for the connection details in the database.
- Maintenance mode is
initiated if the device is not already in maintenance mode.
- EFA replays the
backed-up configuration specified by the
config-backup-id
parameter of the efa inventory rma
execute command.
- EFA begins the
drift reconcile process, which involves device discovery, device update,
and fabric and tenant reconciliation. For more information, see Drift and Reconcile.
If the RMA
command fails during this stage, you can manually run the drift
reconcile process from the CLI. If the RMA process fails for any
other reason, restart the RMA process.
- When drift reconcile is
complete, the device is taken out of maintenance mode.
- During the RMA process,
EFA health checks are deactivated and RASlog does not trigger drift
reconcile.
- Install the HTTPS or OAuth2 certificate on the
new device.
The following conditions result in the RMA
process failing:
- If there is mismatch in device IP
and credentials
- If the device maintenance mode is
not successful
In both the conditions, reject the device replacement with the new
device.
