The all_ports_down.py
script below was deployed—as a temporary
workaround—to ensure that if a port-channel is shut down the members are also shut down.
To access this script and related resources, refer to https://github.com/extremenetworks/ExtremeScripting.#!/usr/local/python/3.5.2/bin/python3 import getopt import json import sys import io import re import pdb from CLI import CLI int_down_raslog = 'NSM-1020' int_up_raslog = 'NSM-1019' shutdown_string = '' match = None raslog_triggers = {} output = '' # For argument processing: options, remainder = getopt.gnu_getopt(sys.argv[1:], '', ['raslog-triggers=']) for opt, arg in options: if opt in ('--raslog-triggers'): print('--raslog-triggers: ', arg) output = io.StringIO(arg) raslog_triggers = json.load(output) # Opening a file for logging: f = open("poout.txt", "a") f.write("testing:\n") def po_members(po_num, shutdown_str): # Determines the physical members of the port-channel and executes # a shutdown/no shutdown command as requested for each physical interface: print("inside po_members", po_num, shutdown_str) f.write("inside po_members" + str(po_num) + str(shutdown_str)) members = [] # Executing the show port-channel CLI and matching the output: poCLI = "show port-channel " + str(po_num) + " | begin Link:" output = CLI(poCLI, do_print=False).get_output() print("output =\n" + str(output)) f.write("output = \n" + str(output)) # Iterating over each interface found in the output, and executing the # appropriate configuration commands: for entry in output: print(entry) str1 = "".join(entry) str1 = str1.lstrip() print(str1.startswith("Link")) if str1.startswith("Link"): phy = str1.split("Link: ")[1].split("(0x")[0] members.append(phy) command = "config term\nint " + phy + "\n" + str(shutdown_str) output = CLI(command, do_print=False).get_output() print("cli output = " + command + "\n" + str(output)) f.write("cli output = " + command + "\n" + str(output)) str1 = "" return members # The following section uses the passed information from the event-handler # and calls po_members with the correct information: print('raslog_triggers:\n', str(raslog_triggers)) f.write("raslog_triggers:\n" + str(raslog_triggers) + '\n') if int_down_raslog in raslog_triggers: shutdown_string = 'shutdown' match = re.search(r'interface Port-channel (\d+)', raslog_triggers[int_down_raslog], re.IGNORECASE) elif int_up_raslog in raslog_triggers: shutdown_string = 'no shutdown' match = re.search(r'interface Port-channel (\d+)', raslog_triggers[int_up_raslog], re.IGNORECASE) if match: po = match.group(1) print('Performing operation "' + shutdown_string + '" on members for Port-channel ' + po + '\n') f.write('Performing operation "' + shutdown_string + '" on members for Port-channel ' + po + '\n') members = po_members(po, shutdown_string) print('\tMembers on Port-channel ' + po + ': ' + str(members) + '\n') f.write('\tMembers on Port-channel ' + po + ': ' + str(members) + '\n') f.close()
all_ports_down.py
script
for an NSM-1020
RASLOG:device# python all_ports_down.py --raslog-triggers {"NSM-1020":"interface Port-channel 10 is administratively down."}
all_ports_down.py
script for an NSM-1019
RASLOG:device# python all_ports_down.py --raslog-triggers {"NSM-1019":"interface Port-channel 10 is administratively up."}
device# show port-channel detail LACP Aggregator: Po 10 Aggregator type: Standard Actor System ID - 0x8000,78-a6-e1-45-95-14 Admin Key: 0010 - Oper Key 0010 Receive link count: 4 - Transmit link count: 4 Individual: 0 - Ready: 1 Partner System ID - 0x0001,00-24-38-8b-f1-00 Partner Oper Key 0102 Flag * indicates: Primary link in port-channel Number of Ports: 4 Minimum links: 1 Member ports: Link: Eth 0/3 (0xC006000) sync: 1 Link: Eth 0/4 (0xC008000) sync: 1 * Link: Eth 0/5 (0xC00A000) sync: 1 Link: Eth 0/6 (0xC00C000) sync: 1 device# flex-cli show interface brief Port Link Port-State Dupl Speed Tag MAC Name po10 Up N/A N/A 40000 Mbit Yes 78a6.e145.9562 po11 Up N/A N/A 30000 Mbit Yes 78a6.e145.9563 lb1 Down N/A N/A N/A N/A N/A N/A 0/1 Disabled None None None No 78a6.e145.9519 Ifml 0/2 Disabled None None None No 78a6.e145.951a 0/3 Up Forward Full 10000 Mbit No 78a6.e145.951b 0/4 Up Forward Full 10000 Mbit No 78a6.e145.951c 0/5 Up Forward Full 10000 Mbit No 78a6.e145.951d 0/6 Up Forward Full 10000 Mbit No 78a6.e145.951e 0/7 Up Forward Full 10000 Mbit No 78a6.e145.951f
