The following procedure configures redundant management on port 0/15 with a Mellanox Adapter.
device# configure device(config)# hardware device(config-hardware)# connector 0/15 device(config-connector-0/15)# device#
device(config-connector-0/15)# breakout mode 4x1G device(config-connector-0/15)# end device#
device(config-connector-0/15)# breakout mode 4x10G device(config-connector-0/15)# end device#
device# configure device(config)# interface Ethernet 0/15:1 device(config-hardware)# connector 0/15 device(conf-if-eth-0/15:1)# redundant-management enable device(conf-if-eth-0/15:1)# no shut device(conf-if-eth-0/15:1)# end device#
When using the Mellanox adaptor, only the first member of the breakout board can be used as the Redundant Management Interface. This is shown in the above example.
The following example displays the Redundant Management Interface configuration on SLX 9250/Extreme 8720 devices with 4x10G.
SLX# show running-config hardware connector 0/15 breakout mode hardware connector 0/15 breakout mode 4x10g ! SLX# show running-config interface Ethernet 0/15:1 interface Ethernet 0/15:1 redundant-management enable no shutdown ! SLX# show interface ethernet 0/15:1 Ethernet 0/15:1 is up, line protocol is up (connected) Redundant management mode is enabled Hardware is Ethernet, address is f46e.95a1.f826 Current address is f46e.95a1.f826 Fixed Copper RJ45 Media Present Interface index (ifindex) is 201589248 (0xc040200) MTU 9216 bytes IP MTU 1500 bytes Maximum Speed : 10G LineSpeed Actual : 10000 Mbit LineSpeed Configured : Auto, Duplex: Full Priority Tag disable Forward LACP PDU: Disable Route Only: Disabled Tag-type: 0x8100 Last clearing of show interface counters: 02:45:29 Queueing strategy: fifo FEC Mode - Disabled Receive Statistics: 81295 packets, 6130007 bytes Unicasts: 1212, Multicasts: 71717, Broadcasts: 8363 64-byte pkts: 62703, Over 64-byte pkts: 17088, Over 127-byte pkts: 545 Over 255-byte pkts: 606, Over 511-byte pkts: 117, Over 1023-byte pkts: 233 Over 1518-byte pkts(Jumbo): 0 Runts: 0, Jabbers: 0, CRC: 0, Overruns: 0 Errors: 0, Discards: 0 Transmit Statistics: 742 packets, 66702 bytes Unicasts: 426, Multicasts: 316, Broadcasts: 0 Underruns: 0 Errors: 0, Discards: 0 Rate info: Input 0.005267 Mbits/sec, 9 packets/sec, 0.00% of line-rate Output 0.000000 Mbits/sec, 0 packets/sec, 0.00% of line-rate Route-Only Packets Dropped: 0 Time since last interface status change: 00:00:44
