Port management
The Extreme device allows the port management of
the following features for interface Ethernet ports.
SLX 9540 port management includes the following:
- Supports 54 ports in total.
Ports 1 - 48 support 10G, 1G and 100 Mbps speed (default is10G).
- Ports 49-54 support 40G, 100G;
and also support 4x10G and 4x25G breakout configurations. Default is
100G.
- Forward Error Correction (FEC)
is supported only in 100G mode.
SLX 9640 port management includes the following:
- Supports 36 ports in total. Ports 1 - 24 support 10G and 1G speed
(default is10G).
- Ports 25-36 support 40G, 100G; and also support 4x10G, 4x25G, and 2x50G
breakout configurations. Default is 100G.
- Forward Error Correction (FEC) is supported only in 100G mode.
SLX 9250/Extreme 8720 port management includes the
following:
- Supports 32 ports of 40G and 100G.
- Ports may be broken out into 4x10G or 4x25G.
- SLX 9150-48Y/Extreme 8520-48Y port management
- Supports 56 ports in total
- 48 ports support 1G, 10G, and 25G.
- 8 ports support 40G, and 100G. These ports are able to break out to
4x10G.
- 4x25Gb is supported on 2 ports only (0/49 and 0/56).
- SLX 9150-48XT/Extreme 8520-48XT port management
- 48 ports support 1G and 10G.
- 6 ports support 40G and 100G.
- Ports 49 and 54 support break out configurations of 4x10G or 4x25G.
- Interface Ethernet port management
features discussed this section include the following:
- Port transition hold timer
- Port flap dampening
- Link fault signaling
