Consider the following when you
configure this feature:
- The TM supports egress scheduling,
rate shaping, WRED, and ingress buffer management for insight interface.
- TM egress scheduling and shaping
for the insight interface must be configured under a port-channel interface.
- The QoS configuration is
automatically applied to all ports in the port-channel.
- Follow the same configuration
procedures for ingress buffer management and WRED as you would with a
standard port.
For more information, see
Configuring QoS egress scheduling.
