[admin@SLX]# /fabos/cliexec/ifindex_gen.py -h
usage: ifindex_gen.py [-h] -i INTF_TYPE [-t LC_TYPE] [-m MODE] [-s SLOT]
[-p PORT] [-sp SUB_PORT] [-lp LAG_PORT]
[-vb VE_BRIDGE_ID] [-vi VE_INTF_ID] [-tt TUNNEL_TYPE]
[-ti TUNNEL_ID] [-lbi LB_INTF_ID] [-mi MGMT_INTF_ID]
[-d DISP_MODE]
arguments:
-h, --help show this help message and exit
-i INTF_TYPE Interface type: [phy (physical) | lag | ve | tunnel | lb
(loopback) | mgmt (management)]
-t LC_TYPE LC type: [72x10G | 36x100G]
-m MODE PortGroup Mode: [40g | 100g] (required when LC type is
36x100G)
-s SLOT Slot #: [1-8]
-p PORT Port #: [1-72] for 72x10G, [1-60] for 36x100G LC type
-sp SUB_PORT Sub Port #: [1-4] for break-out ports (required when LC
type is 36x100G, PortGroup Mode is 40g and break-out is
enabled)
-lp LAG_PORT LAG Port #: [1-512]
-vb VE_BRIDGE_ID VE Bridge ID: [0-255]
-vi VE_INTF_ID VE Interface ID: [1-4096]
-tt TUNNEL_TYPE Tunnel type: [vxlan | gre | nvgre | mpls]
-ti TUNNEL_ID Tunnel ID: [1-1024]
-lbi LB_INTF_ID Loopback Interface ID: [1-255]
-mi MGMT_INTF_ID Management Interface ID: [1-2]
-d DISP_MODE Output Display Mode: [bin | dec | hex | all] (default:
dec)
