Using the tpvm command
The tpvm command, in privileged EXEC mode, allows you to manage TPVM with a variety of subcommands that do the following:
  • Install, start, stop, and uninstall TPVM
  • Specify the default behavior when SLX-OS boots
  • Add or remove disks and show the disk information
  • Print out IP addresses set on TPVM
  • Change the root password on TPVM
  • Use the help keyword for details on all options
Install TPVM:
tpvm install
device# tpvm install
Uninstall TPVM:
tpvm uninstall [ force ]
force: clear installation or uninstallation error(s) then try to uninstall (forcefully)
device# tpvm uninstall
uninstallation succeeds
To force the clearing of installation or uninstallation errors, use the force keyword:
TPVM uninstallation failed
device# tpvm uninstall force
To start TPVM:
tpvm start
device# tpvm start
start succeeds
To stop TPVM:
tpvm stop
device# tpvm stop
stop succeeds
To automatically start TPVM at the next reboot of SLX-OS use auto-boot enable:
tpvm auto-boot enable
device# tpvm auto-boot enable
To prevent TPVM from starting at the next reboot of SLX-OS:
tpvm auto-boot disable
device# tpvm auto-boot disable
auto-boot disable succeeds
In this case, the tpvm start command is required to enable TPVM.
To display the current status of TPVM, or any errors, use the following:
show tpvm status [ clear-tag <tag name> ]
clear-tag: clear the runtime error when the 'command' ran
device# show tpvm status
TPVM is running, and AutoStart is disabled on this host.
To clear errors use the clear-tag<tag name> keywords, where the error in this example is "vm_disks":
device# tpvm start
start succeeds
TPVM had runtime error(s) -- these error(s) seem not fatal, and the operation(s) could be retryable
vm_disks: virsh list timed out. TPVM cannot transit to 'running' state
TPVM is installed but not running, and AutoStart is disabled on this host.
device# show tpvm status clear-tag vm_disks
The runtime error can be also removed automatically when the same subcommand succeeds.
To add a new disk to TPVM, use the following commands:
tpvm disk add name <vd[b-x] | auto> size <number | number[bkmg]>
name: The disk name added to TPVM.
            The name must be 'vd[b-x]' or 'auto'.
            Note. The disk name must be the next disk if it‘s not ‘auto‘. For example, if the last disk added to the system is 'vdb', the disk name must be 'vdc'. When ‘auto‘ is used, the system automatically assigns the next disk name.
size: Any positive number.
        Also the following suffix can be added to the end.
               b or B for bytes
               k or K for KiB bytes
               m or M for MiB bytes
               g or G for GiB bytes
         Note. When no suffix is used, the size is taken as GiB bytes. For example, '5' means '5g'.
device# tpvm disk add name auto size 10g
disk add succeeds
device# tpvm disk add name vdd size 512m
disk add succeeds
The maximum number of disks is currently 3. If the number of allocated disks exceeds this list, the add_disk keyword fails. Also, the total disk capacity is limited to 50 Gbytes on the SLX 9540. If you exceed this limit when you create a disk, the add_disk keyword fails.
Use the disk remove command to remove an additional disk from TPVM:
tpvm disk remove name <vd[b-x] | auto>
name: The disk name removed from TPVM.
            Note. When 'auto' is passed, the system removes the latest disk automatically.
                       Otherwise, the disk name must be the last disk added to the system.
                       For example, if the last disk added to the system is 'vdx', the disk removed from the system must be this disk, 'vdx'.
device# tpvm disk remove name auto
'umount' is needed before this disk is removed. Continue? [y/n]: y
disk remove succeeds
device# tpvm disk remove name vdc
Disks must be unmounted before removal from the system. Otherwise, the next added disk will be labeled incorrectly. If the system falls, TPVM must be rebooted to recover.
Display disk information:
show tpvm disk name <vd[b-x] | all>
name: The disk name whose information is shown.
            The name must be 'vd[b-x]' or 'all'
            Note. When 'all' is passed, the information about all disks is shown.
device# show tpvm disk
Value for 'name' : all
disk: vdb
Capacity: 10.00 GiB
Allocation: 196.00 KiB
total:
Capacity: 100.00 GiB
Allocation: 10.00 GiB
Available: 90.00 GiB
device# show tpvm disk name vdb
disk: vdb
Capacity: 10.00 GiB
total:
Display IPv4 and IPv6 addresses:
show tpvm ip-address
device# show tpvm ip-address
IPv4:
eth0 10.24.7.149
IPv6:
eth0 fe80::629c:9fff:fe01:fe43
eth1 fe80::7:d0ff:fe02:100
The show_ip_addr parameter requires the qemu-guest-agent package on TPVM. If this package is removed, the operation fails.
Change the root password on TPVM:
tpvm password
device# tpvm password
root password: ****
re-enter root password: ****
password succeeds
