Enter global configuration mode.
device# configure terminal
Enter interface configuration mode for port-channel 1.
device(config)# interface port-channel 1
Specify the option for strict priority mode to determine strict priority queues.
device(port-channel-1)# qos queue scheduler strict-priority 4
There are seven traffic classes. Specify the weight for the priority If the priority is in WFQ mode.
Return to privileged exec mode.
device(port-channel-1)# end
Verify the configuration.
device# show qos interface port-channel 1
View the VOQ statistics.
device# show tm voq-stat ingress-device ethernet 0/15 egress-port ethernet 0/125
VOQ-Counters:
Priority 0
EnQue Pkt Count 0
EnQue Bytes Count 0
Total Discard Pkt Count 0
Total Discard Bytes Count 0
Current Queue Depth 0
Maximum Queue Depth since Last read 0
Priority 1
EnQue Pkt Count 0
EnQue Bytes Count 0
Priority 2
EnQue Pkt Count 0
EnQue Bytes Count 0
Priority 3
EnQue Pkt Count 0
EnQue Bytes Count 0
Priority 4
EnQue Pkt Count 0
EnQue Bytes Count 0
Priority 5
EnQue Pkt Count 0
EnQue Bytes Count 0
Priority 6
EnQue Pkt Count 0
EnQue Bytes Count 0
Priority 7
EnQue Pkt Count 0
EnQue Bytes Count 0
Save the configuration.
device# copu running-config startup-config
QoS egress scheduling configuration example
