Using the tpvm config Command
The
tpvm config command, in
privileged EXEC mode, allows you to customize the following TPVM optional features:
- tpvm config
ldap: LDAP configurations for TPVM
- tpvm config
dns: DNS configurations for TPVM
- tpvm config
ntp: NTP configurations for TPVM
tpvm config ldap
This section describes the commands used to configure LDAP over TPVM.
- add: Add LDAP
configurations
- basedn: Base Domain Name
- host:
LDAP server IPV4/IPV6 address or FQDN
- rootdn: Root Domain Name
- rootdnpw: Password for Root Domain Name
- ca-cert: LDAP
TLS certificate operations
- import:
Import certificates for LDAP over TLS.
directory: Remote Directory
- filename: Certificate filename
- host: Hostname/IP address
- password: Password for the user
- protocol: Protocol (SCP)
- user: Login name in the host
- remove:
Remove certificates for LDAP over TLS
- remove: Remove
LDAP configurations
- host: LDAP server IPV4/IPV6 address or FQDN
tpvm config dns
This section describes the commands used to configure DNS over TPVM.
- add: Add DNS configuration
- dns-server: Name Server List <IPv4 address>
domain-name
- remove: Remove all DNS configurations
tpvm config ntp
This section describes the commands used to configure NTP over TPVM.
- add: Add NTP configurations
- server: NTP server IPV4 address or FQDN
- default: Reset NTP configurations to default
- remove: Remove NTP configurations
Show Commands
This section describes the show commands used with tpvm
config.
- show tpvm config ldap: Show TPVM LDAP server
configuration
- show tpvm config dns: Show TPVM DNS server configuration
- show tpvm config ntp: Show TPVM NTP server configuration
