device# configure terminal
device(config)# hardware
device(config-hardware)# connector 0/48
device(connector-0/48)# insight mode
For the SLX 9640 use Eth 0/24. The command will toggle the physical port, and will display as port 0/125 in any show commands.
device(connector-0/48)# exit
device(config)# interface port-channel 22
device(config-Port-channel-22)# insight enable
device(config-Port-channel-20)# ip address 10.0.0.1/24
device(config-Port-channel-22)# no shutdown
device# show interface port-channel 22 Port-channel 22 is up, line protocol is up Hardware is AGGREGATE, address is 609c.9f5a.4558 Current address is 609c.9f5a.4558 Interface index (ifindex) is 671088673 Minimum number of links to bring Port-channel up is 1 MTU 1548 bytes LineSpeed Actual : 10000 Mbit Allowed Member Speed : 10000 Mbit Priority Tag disable Forward LACP PDU: Disable Route Only: Disabled Last clearing of show interface counters: 1d23h53m Queueing strategy: fifo Receive Statistics: 0 packets, 0 bytes Unicasts: 0, Multicasts: 0, Broadcasts: 0 64-byte pkts: 0, Over 64-byte pkts: 0, Over 127-byte pkts: 0 Over 255-byte pkts: 0, Over 511-byte pkts: 0, Over 1023-byte pkts: 0 Over 1518-byte pkts(Jumbo): 0 Runts: 0, Jabbers: 0, CRC: 0, Overruns: 0 Errors: 0, Discards: 0 Transmit Statistics: 5 packets, 380 bytes Unicasts: 0, Multicasts: 5, Broadcasts: 0 Underruns: 0 Errors: 0, Discards: 0 Rate info: Input 0.000000 Mbits/sec, 0 packets/sec, 0.00% of line-rate Output 0.000000 Mbits/sec, 0 packets/sec, 0.00% of line-rate Route-Only Packets Dropped: 0 Time since last interface status change: 00:00:21 device# show port-channel 22 Static Aggregator: Po 22 Aggregator type: Standard Number of Ports: 1 Member ports: Eth 0/125 *
