DHCP Server version 4.2.4 was tested on Ubuntu 14.04 (Trusty). The dhcpd.conf file must have option 66 (TFTP Server Name) and option 67 (Filename) set for ZTP. Option 66 is used for the FTP server IP address or host name. Option 67 is used for the ZTP configuration file path.
When the device starts the DHCP process, it sends the DHCP client ID to the DHCP server to get the IP address and options 66/67. The device then downloads the ZTP configuration file from the FTP server. To set up a different ZTP configuration file for different devices, the DHCP Client ID can be used in the dhcpd.conf file. Whenever dhcpd.conf is changed, the dhcpd server must be restarted.
vsFTP server version 3.0.2 was installed and tested on Ubuntu 14.04 (Trusty). The FTP server stores the ZTP configuration file, firmware, switch configuration file, or Python script. The location of these configuration files under the FTP server base directory is flexible.
Apache server version 2.4.18 was installed and tested on Ubuntu 14.04 (Trusty). The HTTP server stores the ZTP configuration file, firmware, switch configuration file, or Python script. The location of these configuration files under the HTTP server base directory is flexible.
The ZTP process can run the script to set up the device configuration automatically. For now, only the Python script is supported. The script takes no parameters.
The script can automate any command line, including SLX-OS and Linux commands, such as the configuration download command, copy ftp:// . . . running-config.
The ZTP configuration file has two configuration sections: common and device-specific. The common section is shared by all the switches in the IP Fabric. The settings in the device-specific section can be used for a single switch or a group of switches with the DHCP client ID. If the host_client_id string matches the starting substring of the DHCP client ID of the switch, the device-specific section is used by the switch.
The following is an example Python script.
# !/usr/local/python/3.3.2/bin/python3 import os import sys, getopt def main(argv): log.write("apply config\n") # change login banner CLI(“conf ; banner login DAD ; end”) # config download CLI(“copy scp://root:extr123@192.169.0.2/castorT.startup.cfg running-config”) if __name__ == "__main__": main(sys.argv[1:])
The following is an example FTP server configuration file.
local_enable=YES write_enable=YES local_umask=022 dirmessage_enable=YES xferlog_enable=YES connect_from_port_20=YES xferlog_std_format=YES listen=NO listen_ipv6=YES pam_service_name=vsftpd userlist_enable=NO tcp_wrappers=YES # dad settings anonymous_enable=YES no_anon_password=YES anon_root=/var/ftp delay_failed_login=30 max_clients=100 anon_max_rate=8388608
The following is an example DHCP server configuration file, dhcp.conf
# ddns-update-style standard; ddns-update-style interim; ddns-ttl 600; ignore client-updates; # Overwrite client configured FQHNs ddns-domainname "infralab.com."; ddns-rev-domainname "in-addr.arpa."; option ntp-servers 192.168.0.2; option domain-name-servers 192.168.0.2; option domain-name "infralab.com"; option domain-search "infralab.com"; default-lease-time 600; max-lease-time 7200; authoritative; log-facility local7; key "extr-key" { algorithm hmac-md5; secret "dtBgNTAoqZmwV5c4SueybjOvhe6OIqgac1uQrzGBv5O4X4nIEBEEGWRf0lCnbFhuIJXGExNBjDdNSqgBMeNI8w=="; }; subnet 192.168.0.0 netmask 255.255.255.0 { range 192.168.0.100 192.168.0.200; option subnet-mask 255.255.255.0; option broadcast-address 192.168.0.255; zone 0.168.192.in-addr.arpa. { primary 192.168.0.2; key "extr-key"; } zone infralab.com. { primary 192.168.0.2; key "extr-key"; } } # cluster switches group{ option bootfile-name "/config/unified-cfg.min"; option tftp-server-name "192.168.0.2"; option routers 192.168.0.2; # sw0 host sw0 { option dhcp-client-identifier = "EXTREMENETWORKS##SLX9240##EXG3342L00V"; hardware ethernet 52:54:00:0E:95:8B; fixed-address 192.168.0.90; # fixed ip address
The following example has three sections: common, switch 1, and switch 2.
version=3 date=03/20/2018 supported_nos=17s.1.03 common_begin vcsmode=SA scriptcfgflag=2 #0-config file only, 1-script only, 2 both script=/script/ztp.py fwdir=/fw/slxos17s.1.03_bld04 common_end # model SLXL9140 hosts host_client_id=EXTREMENETWORKS##SLX9140 script=/script/Frreddomlic.py startup=/config/freedomlic.cfg host_end # model SLX9140 with serial number host_client_id=EXTREMENETWORKS##SLX9140##EXH3327M014 startup=/config/freedom_ospf.cfg script=/script/FreedomZTP.py host_end # model Accton hosts with serial number host_client_id=EXTREMENETWORKS##ModelNumber##SerialNumber startup=/config/AcctonConfig.cfg script=/script/AcctonZTP.py host_end
The following table contains the ZTP configuration file definitions.
Variable description | Description |
version | Only version 3 is supported. |
date | The last modified date. |
supported_nos | The release firmware version supporting the ZTP configuration file. |
host_client_id, host_end |
Host_client_id marks the beginning of the section host_end marks the end. User could set up the switch specific section with full dhcp client id or its prefix. Ex. host_client_id=EXTREMENETWORKS##SLX9140##EXH3319M01J script=/script/dad1new.py host_end |
common_begin, common_end | The setting in the section will be shared by all switches. |
vcsmode=SA | Only standalone mode is supported. |
vcstimeout |
If omitted, the default is 60 minutes. The timeout to wait for ZTP to complete configuration file download or Python script. If the configuration download process or Python script has issues, the zero touch provisioning process will stop the download after timeout and claim that ZTP is complete. You will need to increase the timeout if configuration download or Python script takes a long time to complete. |
fwdir | Firmware path in the FTP/HTTP server. For example Fwdir=/fw/ slxoss17r.1.00_bld34. If base directory of the server is /var/ftp, then the absolute path of firmware in ftp server is located at /var/ftp/fw/slxoss174.1.00_bld34. |
startup | The path to the switch configuration file in the FTP server. If omitted, the switch will take the default configuration. The value can be "default" or user configuration file. |
scriptcfgflag |
The default is 0, when not specified. The meaning of the value is: 0 - only use startup, script is ignored 1 - only use script, startup is ignored |
script | The device configuration Python script file. |
ZTP has two commands, dhcp ztp log and dhcp ztp cancel. These are illustrated below.
device# dhcp ztp log ZTP, Sat Feb 17 02:48:51 2001, ========== ZTP start ========== ZTP, Sat Feb 17 02:48:51 2001, disable raslog ZTP, Sat Feb 17 02:48:51 2001, CLI is ready ZTP, Sat Feb 17 02:49:19 2001, inband ports are enabled ZTP, Sat Feb 17 02:49:19 2001, serial number = 771232X1750017 ZTP, Sat Feb 17 02:49:19 2001, model name = AS7712-32X ZTP, Sat Feb 17 02:49:19 2001, use both management inteface and inband interfaces ZTP, Sat Feb 17 02:49:19 2001, checking inband interfaces link status ZTP, Sat Feb 17 02:49:19 2001, find link up on intefaces: eth0 ZTP, Sat Feb 17 02:49:19 2001, start dhcp process on interfaces: eth0 ZTP, Sat Feb 17 02:49:20 2001, interface eth0 receives dhcp response ZTP, Sat Feb 17 02:49:20 2001, ping server 192.169.0.1 ZTP, Sat Feb 17 02:49:21 2001, ping succeed ZTP, Sat Feb 17 02:49:21 2001, download ZTP config file from https://192.169.0.1/config/ztp.conf ZTP, Sat Feb 17 02:49:21 2001, download ZTP config file from http://192.169.0.1/config/ztp.conf ZTP, Sat Feb 17 02:49:21 2001, receive ZTP configuration file [ztp.conf] ZTP, Sat Feb 17 02:49:21 2001, interface eth0 connectivity test pass ZTP, Sat Feb 17 02:49:21 2001, download switch config file [startup.cfg] ZTP, Sat Feb 17 02:49:21 2001, ZTP configuration sanity check pass ZTP, Sat Feb 17 02:49:22 2001, skip firmware upgrade ZTP, Sat Feb 17 02:49:38 2001, replay config file... ZTP, Sat Feb 17 02:50:25 2001, commit configuration ZTP, Sat Feb 17 02:50:25 2001, ZTP succeed ZTP, Sat Feb 17 02:50:25 2001, enable raslog ZTP, Sat Feb 17 02:50:25 2001, ========== ZTP completed ========== device# dhcp ztp cancel Warning: This command will terminate the existing ZTP session Do you want to continue? [y/n] y
The following cancels the current ZTP session.
Before making any configuration changes from the CLI, the user must reboot the switch to return to the default configuration. A reboot abandons all switch configuration set by ZTP.device# dhcp ztp cancel Warning: This command will terminate the existing ZTP session Do you want to continue? [y/n] y
