Auto negotiation is supported on ports 1 to 24 on the front plate. However, ports 25 to 72 support 1G mode without auto negotiation.
Auto detection occurs when the interface speed is configured based on the detected optic type.
You can manually configure the port speed. In manual mode, the inserted optic must match the configured speed. Otherwise, the link will not come up. You can configure 1G mode with or without auto negotiation. The following speed matrix shows different combinations of modes on the SLX 9540.
Ports 1 to 48 on SLX 9540 |
speed auto (default) |
Auto-detection:
speed 1000 | Force to 1G mode, AN disabled |
speed 1000-auto |
enabled
speed 10000 | Force to 10G mode |
Speed 100 |
no speed | Equivalent to speed auto |
