Exclude Missing VLANs
Use this task to manually specify VLANs to exclude from Missing VLANs anomaly detection.
  1. Go to CoPilot > Anomalies, and select .
  2. Select an existing Excluded VLAN ID, and then select Edit, or select Add.
  3. Select Manual.
    Alternatively, select CSV Import and choose a CSV file. To dismiss existing false positives for the VLAN that you want to exclude, select Dismiss existing Missing VLANs.
  4. In the Excluded VLANs field, type the VLAN IDs to exclude, separated by a comma after each ID.
  5. From the Exclude from Sites menu, select the corresponding check box for each site from which you want to exclude the VLANs specified in Step 4.
  6. Select ADD.
