The Manage > Devices window provides resources to facilitate device management. These resources include:
Status indicators appear in the Device list and in the banner above the Device list.
Under the Status column in the Device list, icons appear that are designed to
provide useful device status information. Multiple status icons can be associated
with a device. Hover over any icon to view a label indicating what the icon
represents. Some status icons are interactive. For example, select either the
Configuration Audit Match icon or Configuration Audit Mismatch
icon
to open a pop-up window detailing device configuration changes that have been made
since the last configuration update.
The Configuration Audit icons do not apply to locally managed switches.See Device Status Icons for a description of each icon that can appear in the Device list and the actions users can take.
The status indicators in the banner above the Device list display network-level connection information and notifications. This data automatically updates whenever you open the Devices window. Banner Status Indicators describes the information each indicator provides and actions users can take:
Status Indicator | Description |
Connection Status | Shows the total number of connected devices and how many are
online versus offline. Select the adjacent ![]() |
Total Apps | Shows the number of applications in use. Select the adjacent
Clients | Shows the number of connected clients. Select the adjacent (non-zero) value to open the ML Insights > Client360 window to view more details about the clients. See About Client 360 for more information. |
Users | Shows the number of connected users. Select the adjacent (non-zero) value to open the Manage > Users window to view more details about the users. See Manage Users for more information. |
Anomaly Detection | The Anomaly Detection indicator shows the number of anomalies
detected over the past 24 hours. Hover over the ![]() |
Alerts | The Alerts indicator shows the number of Unacknowledged
Critical alerts raised over the last 24 hours. Hover over
the ![]() |
Most of the tasks performed in the Device list require that you first identify the targets of any actions to be taken by selecting the check box associated with the devices in the Device list. You can individually select a target device, or you can select Select All and clear the check boxes for devices that you do not want to include.
When there are multiple pages of devices, to select all the devices on all pages, choose All Pages above the table. To deselect all the devices on all pages, choose None.Note
After you select All Pages, the Actions menu displays only the following basic management actions:Only actions applicable to the selected device are available.
Choose from the following actions:
See Add Devices Overview for information about the different methods you can use to add devices to the ExtremeCloud IQ network.
This option is not available for locally-managed devices.
See Device Details Overview for details about the Monitoring and Configuration resources available at the device level.
Most device options are unavailable if an unmanaged device is selected, either alone or together with managed devices. To change the management status for one or more devices, select each target device in the list, then select Actions and use the drop-down menu to choose Change Management Status.See Push the Device-Level Configuration to the Device for details.
See Device List Columns for further detail.
