View Device Inventory
The Device Inventory displays a list of Access Points, Switches, or Clients currently being monitored on a heat map.
The Access Points and Switches inventory lists provide the following details about each device:
  • Hostname: The name assigned to the device.
  • Status: The current operational state of the device.
  • IP Address: The unique network address assigned to the device.
  • Show/Hide: An option to toggle the visibility of the device on the heat map, allowing for a more customized and focused view of your network's real-time status.
The Clients inventory list provides the following details about each device:
  • MAC Address: The unique identifier assigned to the device.
  • Type: Filter by different client types.
Use this task to toggle the visibility of Access Points and Switches and filter Client types on a selected heat map.
  1. Go to Manage > Real time maps.
  2. Select a floor from the location list.
    The selected floor must include a floor map. For more information, see Add a Floor Plan.
  3. Select the icon.
    You can use the Search field to find a specific device if your device list is long.
  4. Select an Inventory Type.
    • Access Points
    • Switches
    • Clients
  5. To hide an Access Point or Switch, select the corresponding icon.
  6. To show a hidden Access Point or Switch, select the corresponding icon.
  7. To filter Client types, select and activate a filter option.
