Add a Credential Distribution Group
Use this task to create Credential Distribution Groups for members of your organization who are permitted to distribute log in credentials to visitors.
When defining Credential Distribution groups, the required details for Admin Account depend on the specific type of administrative account.
In most cases, you enter the email address associated with the Guest Management account in Account Management Settings. However, if the Guest Management account was created automatically by Self-Service SSO (and has a blue SSO badge), you must use the automatically generated saml.login user ID (such as, abcdefg12345@saml.login). This value must be obtained by the GET /users XAPI call. For more information, see the ExtremeCloud IQ XAPI Swagger or ExtremeCloud IQ API Reference.
  1. Hover over Account, and then select Global Settings.
  2. From the Accounts menu, select Credential Distribution Groups.
  3. Select an existing group, and then select Edit, or select Add.
  4. Configure the settings.
    SettingDescription
    Group Name(Required)
    Type a name for the group.
    Admin Account(Required)
    From the menu, choose Active Directory User or Guest Management Role User.
    Member OfActive Directory User only
    Enter the Active Directory user group for the account. If the account is a member of multiple groups, type the name of the first group, press Enter, and then enter the next group name.
    Guest Management User(Required) Guest Management Role User only
    Enter the access control role to assign to a group member.
    Credential RestrictionSelect Restrict the number of credentials per employee to, and then select the number of credentials that group members can distribute.
    Registration OperationSelect Email Approval.
    Enable User GroupsAdd existing user groups to add to this credential distribution group either by selecting Select All, or by selecting the check boxes for individual user groups.
  5. Select SAVE.
