Viewing the roaming trail of a connected client to an access point (AP) on a real-time map has many benefits:
- Troubleshoot Connectivity Issues: Identify areas where the client might be experiencing weak signals or frequent disconnections.
- Optimize Network Performance: Understand the movement patterns to adjust the placement of APs to ensure better coverage and reduce dead zones.
- Monitor Security: Detect any unusual or unauthorized movements within the network, which could indicate potential security threats.
Use this task to view the roaming trail of a selected AP client from a real-time map.
- Go to .
- From the Global View location list,
select a floor or use the Search field to search for a specific site, building, or floor.
The
Search field helps you find
a specific location in a large network. Enter the first few characters to see a list of
locations. The more characters you enter, the more precise the search results will
be.
The selected floor must include a
floor plan. For more information, see
Add a Floor Plan.
- Select the purple halo above a device.
The purple halo shows the number of connected clients on the device.
- Select an available client, and then select Client Roaming.
A split window displays:
- Left Pane: This pane displays the map and showcases how the client roamed.
- Right Pane: This pane displays the roaming view details, including the Client Name, Roaming Time, and Total Number of Roaming Events. The graph illustrates the roaming events and trails. Hover over a client or trail line to see a small pop-up with roaming details.
- To view the roaming trail, from the right pane, select Play.
By default, the roaming view displays client roaming details for the previous hour.
The roaming trail plays within the top map pane, showing where the client roamed and how long it took:
- A green roaming trail signifies a good roam (less than one second).
- A red roaming trail signifies a slow roam (longer than one second).
- To narrow the roaming time frame, from the right pane, select the Date & Time Range drop down, select a Start Date and End Date, select a Start Time and End Time, and then select Done.
Select Reset to Default to reset back to the default time frame.to reset back to the default time frame.
- To exit the roaming view and return to the real-time map, select X in the bottom pane.
