Configure Management and Native VLAN
Policy Settings
This task is part of the network policy configuration workflow. Use this task to configure Management
and Native VLAN policy settings for a network policy.
Go to Configure > Network Policies.
Select an existing network policy, and then select , or select to create a new
policy.
From the Policy
Settings menu, select Management and Native
VLAN.
Select an MGT Interface VLANfrom the menu, or select .
For a new MGT Interface VLAN, configure the
settings.
Type a Name for the new VLAN object.
Type a VLAN ID for the new VLAN object.
If you want to use classification, select Apply VLANs to
devices using classification.
